P700 Shifting issues…. With video
Huntsonora
10
34
Colorado
Picked up a 2016 with 60 miles on it a few weeks ago. Not shifting into 3rd gear and when I get to about 30-31mph is stutters which is probably a rpm rev limiter. I changed the oil with amsoil and reset the maintenance reminder wrench icon thinking it was just the old original oil. I have disconnected the battery to reset the ecu and will see if that helps
Any assistance is greatly appreciated
Here’s the video…..
43,567
Here’s the video…..
That "-" to the left indicates something going on with the shift position switch or wiring. Sould say D, N, or R. Fix that and the rest will come good.
Huntsonora
10
34
Colorado
where is the shift position switch? This thing has sat for a while and may just need to be cleaned uo
thank you!
43,567
thank you!
On the back of the engine driver's side, just under the shift arm/shaft, IIRC. Suspect rodent damage.
43,567
Sorry... slightly above and to the right of the shift lever/shaft. Black disk with 2 bolts and wires.
ByronM
ByronM
180
369
St Charles, Il
When mine did that it was a bad ground, the one on the engine but It wouldn’t hurt to put a wrench on the battery and the positive wires too.
Huntsonora
10
34
Colorado
Think I found the problem 😡
How expensive will this be? I hate mice
AE85A933 0A12 4323 A43F 286B331100AC 4C5CCF22 F4E0 4B72 A253 6036B118ED6D C0BBE031 39A7 4691 A2CA 26C5790D1E59
Fatsquatch
Fatsquatch
Approved Member
120,508
1,006,221
Hidden
If you can solder, it won’t be fun but you can fix it yourself. If not a dealer will probably make you buy a new wire harness. That being the case I’d find a friend or shade tree mechanic that can help you out.
68,145
Totally agree.
Find a shade tree mechanic or try it yourself.
I enjoy these types of repairs myself.
WagginTail
WagginTail
1,641
6,023
SC
Fastenal sells some butt connectors that are crimp and solder and have heat shrink on them. Just crimp them on then heat the solder with a heat gun or butane torch. I used these at work to fix some wiring on a drill rig and they worked great. You could add extra heat shrink tubing over the connectors if you wanted to.
WagginTail
WagginTail
1,641
6,023
SC
Power phase is the brand. I'm sure there are other brands out there. You would need the red ones.
Screenshot 20210821 184632 Chrome
