P500 RAM Mount Help needed P-500
RobbieS
RobbieS
78
163
Pagosa Springs, Colorado
I want to be able to mount an iPad air (9.4' x 6.6') as a navigation device using RAM Mounts. I've searched Amazon and the variety is frankly, overwhelming. I'm not sure where to mount the ball, or where is the best attachment for the P-500.
I would sure appreciate any advice.
21,756
93,275
Have you got a picture of your dash?
Where do you want it mounted? over head? dash? windshield pillar?
Reactions: Mudder
NTC/TAP Transition Member
11,880
90,564
BikeBandit had ROP OEM quick clamps if that helps. Mounted 2 way radio. 41.3MM dia tube (1 and 5/8 inch diameter - approx). Think of similar to rear view or side pillar mirror.
7AEE2010 AEA2 4A81 9E7C BA7257DA9661 1ED74E8A F924 44C8 81F5 EC6B1014BE99 13D7EF7A 41EE 4C42 B3B8 686B458463A1
Reactions: Vaden01
RobbieS
RobbieS
78
163
I don't have any real extra room on the dashboard. I'm mainly want to know what others have done to mount the RAM Mount on the P-500.
Thanks
Reactions: Dp5hunter
HUCK
HUCK
1,047
2,319
ARIZONA
I have a split mount mounted just ahead of the steering wheel and it holds two iphones , one for nav one for phone . Keeps them right in view and easy to access .
Reactions: RobbieS
RobbieS
RobbieS
78
163
Huck, I have an iPhone now on a magnetic post that seems to work ok. My problem is that I'm getting older and the iPhone mapping (GAIA) which doesn't need an internet connection, we're finding that the screen is too small. I have an iPad air that is older (already paid for :) and would be perfect....it is 9.4" by 6.6", which is pretty big for putting on the dash.
21,756
93,275
This is how I have my ipad mounted. I would suggest a better attachment than the X grip I used. I am not impressed with it. I have a new tablet to install over the winter. It will be in the same location, but uses a locking dock from Ram. It will charge as soon as you place it in the dock.
IMG 20170820 125730
HUCK
HUCK
1,047
2,319
ARIZONA
I see your point . I have a friend that mounted his on the roll bar above and in front of his face . He likes it , I don't .
RobbieS
RobbieS
78
163
Yep, that's what I'm looking to see. Think that location will work fine for my P-5. Is the x grip what is holding the tablet?....or is it the mount on the dash? That looks like a great setup, like that it is near the 12v outlet too. Any idea which locking dock from Ram you are considering?....any clues here are greatly appreciated!!
Heloron
116
290
Oroville, California
IMG 0807 The magnetic attached mount connected to the ball works really well, easy on and off and quick when changing devices, from cell phone to iPad, etc,. It's what we use in our utility Helicopters, and on my Honda Foreman and P500.
21,756
93,275
I will see if I have all the components here at camp this weekend to mock up a picture for you. Nothing wrong with the X grip, I just don't care for it for this application.
Hit up amazon and look up "ram track" see if you can mount a piece on your dash. You can add a cup holder for your passenger, or some other ram accessory to make your ride better.
