Talon R turning radius improvement?
mikegriffin84
Colorado
Oddly enough Honda shows the four seater which is even longer than the r yet they have the Same turning radius I have a talen R model and I think the radius is just a little bit pathetic
The 4 seater X is longer than an R but uses the X a-arms. The net result of that longer length and x arms is that the 4 seater ends up with the same turning radius as the R.
Reactions: Bigshow
JimmyTalon
130
235
SE Minnesota
Good info, thanks. Would you know if there is any difference in the steering rack itself between R and X and 4 seater? Thanks again.
Bigshow
Bigshow
162
729
Ohio
On the 2 seaters the X has different amount of teeth on the rack gear vs the R rack gear. You would have to check part numbers on the rack gear between the X 2 vs X 4. It is covered in the links to other threads by SnuffnWhiskey.
