P1000 questions on lift variations
Sterno
11
Looking for advice....
I have a 1000-5 and Im looking to put a lift on it, I have seen some great set ups on here. Im looking for Clearance more than height and better ride.
#1 I like the Super ATV 3inch lift, can you also use the arched A arms also? The arched A arms seem to really give you the clearance underneath. Does using the lift and the arched a arms increase height? I'm only looking to run 28 or 29 inch tires, (I've heard loss of power running bigger).
# will adding new shocks such as FOX or ELK add to height?
Thanks in advance
Sterno
WV
Tigermark
Tigermark
Outside looking in.
Welcome to the forum from NW Arkansas!
You can run 30' tires with the arched Forward A Arms with no lift. You can run up to 28' tires with no suspension modifications. I'm running 28' tires with a highlighter kit and fox shocks. I love the setup and how it handles. You can increase your ride height by adjusting the pre-load on the shocks, however I think you will be much happier with the ride and handling if you use the Highlifter Kit .
Reactions: knuckledeep and JTW
my99svt
my99svt
I identify as a lesbian
1,267
5,248
Broken Arrow, Oklahoma
But if you have the trail armor skids you will have to trim them.
What he said!! I really like the ride a feel with the HL lift..
Reactions: Tigermark
pct
pct
Lost in the hills
790
1,023
Letart WV
Welcome from WV you would fine with just the super atv arms no lift needed to run a 30" tire spring spacer on the front to level it and you should be fine
Reactions: drfubar
Sterno
11
Ok next question which with new shocks fox or elkn
pct
pct
Lost in the hills
790
1,023
Letart WV
I would go with just arms from satv first you can a 30" tire without a lift If you want a tire that big
Do the arms just give clearance, that's what I'm after
The lowers are arched up to give you extra clearance under the arms. They are also moved forward 1.5" to allow slightly larger tires.
I like them over the others because of the camber adjust, warranty, and the fact that it doesn't lift the machine. I am not a bogger, Ill play in the mud a bit and Ill cross water if its in my way, but Id rather ride trails with hills and rocks. There is a 3" SATV lift that will work with the arched arms so you can get the best of both worlds if you want a lift, I wouldn't go past 28-30" tires though. Reverse is too high geared as it is.
Honda pioneer 1000 1 5 forward offset high clearance a arms 01
Sterno
11
That's what I was after. So Im going to get the Arched A arms for Clearance, Run a 28-29inch tire, with new Shocks, Fox Vs Elka
Reactions: Smitty335 and pct
pct
pct
Lost in the hills
790
1,023
Letart WV
I think that you will be happy with them
211,304
Don't know about the Foxs, I have Elka Stage 5's all the way round, cranked slow speed compression two clicks and removed torsion bar, handles great and articulates in rocks, but the stage 5's are double the cost.
A
ajones38251
Knoxville, TN
Can I just get the Arched A Arms for the front and not the back and run a 30” tire all the way around? Also does the 2.5” highlifter lift make it ride any rougher or the suspension more stiff?
A
Average_Joe
970
3,676
Gainesville, Fl
  2. Other Brand
The suspension is stiffer with the HL lift but personally it doesn't feel as rough on bumps. The lift kit moves the top mounting hole outboard standing the shocks up more. Bumps don't seem to effect the Pioneer with the lift as much vs pre-lift I like the stiffer suspension
Reactions: JTW
A
ajones38251
Knoxville, TN
I ride on a lot of rocky terrain. So would you say the HL lift would make it a smoother less bumpier ride? Or would it just better to get the SuperATV arched a arms for the front end (not the back) to fit a larger tires all the way around?
