Purchased Kawasaki Ridge Limited
ehart814
ehart814
1,701
3,888
NWPA
IMG 4438
Little snow storm going on the past couple days. Started getting a bit heavy last night so I went for a ride with one of my pups. The HVAC did it's job, kept warm and the defrost and wiper kept the windows clear enough. I believe all HVAC buggies have a little bit of an issue keeping the coolant temp up high enough to make good heat. The coolant temp would get below 150 at times but it stayed warm enough. I may try a piece of cardboard in front of the radiator. I have my complaints about the machine, but there's no denying that the cab is very nice and comfortable, especially when the weather is bad. Still waiting on my snow plow bracket to come in - then the mission will be making a Tusk snow plow work with a KFI snow plow mount. Hopefully no big deal
Se far
19
72
St. Louis
Nice,
This is a nice concept that Honda is missing out on. Honda is so close to having similar, but it's like they just gave up and said F-it. Lets just slap on this door that has air holes all over the place.
I know its kinda a niche market within the industry, but for older folks or those that dont want to get dirty and even street legal groups its going to be a requirement that will push them into the sealed units like the Ridge or Canam
Keep us updated on any issues and accomplishments.
Thanks.
And the folks that want those things don't mind the belts, which is the only reason I have a Honda. Mine doesn't work hard but it works. I upgraded my Pioneer this year and couldn't believe the prices on the fancy Polaris and Kawasaki. They are amazing units though.
I'm not surprised that Honda isn't serving this niche-- I can't think of any Honda that is cutting edge for anything. Not complaining but they don't seem to care about anything but reliability.
ehart814
ehart814
1,701
3,888
NWPA
I def don't love the belt - that's one of the biggest reasons I stuck with Honda side by sides until now. My machines play a little, but I definitely work them and the Hondas never complained. This Kawi has some big shoes to fill, but so far I'm happy with it.
My opinion (for what it's worth) is that Honda will eventually have an HVAC model. But as a Honda fan for many years, I've learned not to get impatient with them. I decided I wanted HVAC and I wanted it now, so I figured Kawi was probably the safest non-Honda option available and there are huge discounts on the Ridge models right now.
Bighat
Bighat
909
3,866
Gallipolis Ohio
Putting the cardboard in mine in the morning. Gonna be real cold for a while.
906UP
906UP
14,894
141,569
da Yoop
Be careful with that, if you do keep any eye on your temp gauge. We're about 600 miles North of you and ride around all winter without blocking the radiator. The thermostat will keep the engine at operating temperature. Our buggies run at 2 bars, same as they do in the summer.
ehart814
ehart814
1,701
3,888
NWPA
Did the first service. Super easy. Guess what guys... SPIN ON FILTER! Trans and front diff are super easy too. Didn't have to use a piece of tube or a pump to refill.
Really happy the KFI plow mount works with my old Tusk snow plow that I had on my Pioneer. The only thing I need to do is drill out the plow for larger pins - the KFI mounts use larger pins than the Tusk so it's a little sloppy. But it went right on no problem!
Image3 3
Image2 3
Image1 6
Image0 11
Robobrainiac
Robobrainiac
2,662
9,243
Really happy the KFI plow mount works with my old Tusk snow plow that I had on my Pioneer. The only thing I need to do is drill out the plow for larger pins - the KFI mounts use larger pins than the Tusk so it's a little sloppy. But it went right on no problem! View attachment 455781View attachment 455780View attachment 455779View attachment 455778View attachment 455777
If your rig is similar to my Teryx4 the fluid changes are really easy. When I purchased my first service kit EVERYTHING was in a single box designed for my rig. It included a disposable cardboard funnel and a pair of rubber gloves. I bought mine from the dealer at time of purchase. I felt like it was cheap considering what it came with. I think I paid $90.
Reactions: Smitty335 and ChadD
ehart814
ehart814
1,701
3,888
NWPA
I got all my stuff from a local independent shop. Used Honda GN4 engine oil and used amsoil in the diff and transmission. I paid $190 for all that and the snow plow attachment plate so it was very reasonable considering the plate was over $100 by itself
GRANITE
GRANITE
People Dying to come see me!
1,625
9,499
Brookville, Indiana
I figured it would look just like the pop ranger crews do
Reactions: ChadD
210,635
I guess now your going to tell us now that you don't need tools to check the oil level. Turd! HA!
Reactions: ChadD and Backwoods
DRZRon1
DRZRon1
1,388
4,285
As long as temp doesn’t get over 210ish I wouldn’t worry. As you know, the heater is simply another radiator - heat transfer widget. Essentially you are running 2 radiators - so blocking one off or turning the can heater off for a while will raise the temp up.
Sounds like a very nice ride.
Reactions: ehart814 and ChadD
ehart814
ehart814
1,701
3,888
NWPA
After some more time with it, I realized that (just like any car) if you have the AC on it turns on the cooling fan. I usually run the AC for the drying/defogging effect. Once I shut that off, it warms up quicker and the heater performs better. Didn’t figure it out immediately because you can’t hear the cooling fan run from the drivers seat
