Please help
P
paulmordasini
El Centro, Ca.
What is the softest setting on the factory Fox shocks on the Talon 1000S2X. (2 persons)?
DRZRon1
DRZRon1
1,419
4,358
there are three settings on the QS3 shocks for the 1000S2X
1 - Firm as hell, wonder what Honda was thinking
2 - Chiropractor needed after 5 miles
3 - Simulates a piece of pipe welded between frame and trailing arm
Softest setting is 1
5,742
26,315
There izn't a softest setting on an X-2. Your three choices are - 1. Hard. 2. Harder 3. Hardest. :oops:
Workarounds -
1. Beadlocks and low tire pressures.
2. Disconnecting the swaybar if you aren't backing it into the turns like Robby Gordon.
3. Aftermarket springs, Bandit is a popular choice.
4. Shock revalving.
5. 14" wheels will give you a taller (softer) tire sidewall for a similar sized tire but will also put your calipers closer to the wheel. Some haven't had a problem with that but I almost punched a hole in my 15" rim waaaaay out in the desert. :eek:
1670096968712
116,565
Welcome from your little brother state , Michigan!
The answers above are what you after for the most part. But whats your motive for asking! We can help u further with that.
Also, we need pics of you X2 ASAP
Pics Or it Didnt Happen
Workarounds -
4. Shock revalving.
You forgot a couple of options
GForce racing
George White Double E racing
