Coeus
Major General
Keep us postedThe prototypes are done. I'll try to get an update on the first production run.
Thanks for the update…will either get something else or wait for y’all to release prototypes
The 2022forest and trail edition axles are different too. They are bigger at the hub. So his advert of 2017-2021 LE & SE is correct, that's all they fit.Very nice. Shouldn't your application also include 2022 Forest and Trail? I don't even think there's an LE anymore, right? Don't wanna confuse the new guys...
Btw @SuperATV - do you write all of the copy for these part descriptions?
Pretty sure the 22 axles are different too. Splines, thread, nut size at hub are all different I believe.No idea on that 2022 Forrest and Trail, but I'll cross reference the OE numbers and toss it up on the website if they're the same! Thanks for the heads up!
And no....Its probably a smart marketing, management, and legal decision to not allow me to write the copy. I tend to have a little too much fun with this stuff...and I like to use more colorful words.![]()
That's right! FINALLY a big heavy duty axle for the LE models!
Link: https://www.superatv.com/honda-pioneer-1000-axles-rhino-2-0-brand?sku=AX-3-64-RR-0-DT-LE
- Honda Pioneer 1000 Limited Edition : 2017+
- Honda Pioneer 1000-5 Limited Edition : 2017+
Yep! Fits all current LE models.@SuperATV can I get a confirmation that these will also fit a 21 1k5 Special Edition as well? Have a noisy right rear and might as well upgrade vs getting parts from honda if they do fit.
$ 239.00 is that per set?Yep! Fits all current LE models.
Here's a quick link for reverence. https://www.superatv.com/honda-pion...4-F-0-DT-LE&wishlist=null&wishlistItemId=null
Ok. Sorry to be a pain but, the oem part numbers it’s listed as replacing are not LE axle numbers from what I’m seeing. Just want a definite answer before I own $500 in axles I can’t use. The axles include the gears on them for the i4wd system?Yep! Fits all current LE models.
That’s price per each full rear axle according to the website.$ 239.00 is that per set?
You wont get a responce from him till later tomorrow. But yes they do have the gears, A friend got a set and they looked good and purdy.Ok. Sorry to be a pain but, the oem part numbers it’s listed as replacing are not LE axle numbers from what I’m seeing. Just want a definite answer before I own $500 in axles I can’t use. The axles include the gears on them for the i4wd system?
Ok! Thanks for the confirmation!You wont get a responce from him till later tomorrow. But yes they do have the gears, A friend got a set and they looked good and purdy.
.... A friend got a set and they looked good and purdy....
Yep, just make sure to hit the LE model in the dropdown box.Ok. Sorry to be a pain but, the oem part numbers it’s listed as replacing are not LE axle numbers from what I’m seeing. Just want a definite answer before I own $500 in axles I can’t use. The axles include the gears on them for the i4wd system?
Thanks!! I appreciate the time and confirmation.Yep, just make sure to hit the LE model in the dropdown box.
No prob! Thank you!Thanks!! I appreciate the time and confirmation.
No prob! Thank you!
And spread the word! My bean counters are giving me some chit because they aren't flying off the shelves like I had told them. We gotta pump those numbers so I can make sure we can keep them in production!![]()
Tell your bean counters it's Christmas and at over $ 500.00 for a set, that's steep this time of year. Guess LE doesn't stand for less expensive?No prob! Thank you!
Need to pump them up in the mud riding groups. I don't think I've ever seen an LE with a broken axle riding in the mountains over the last few years. I've seen a few down here at the mud parks when they've got the lifts and stuff on them though.No prob! Thank you!
