P1000 Pioneer 1000-5 Honda upper doors
Stevo
Stevo
86
144
Illinois
Put on upper doors which I bought about a year ago. Had a 50 degree day so was lucky to get a window of opportunity to install them.
Main issue was getting the bolt thru tube frame into the riv nut. Finally got a metric bolt cut head off of it to make it a threaded stud. Bent it at an angle installed it in riv nut and slid door over it and put a washer and nut on it. Was a poor design by Honda. Top of door has an angle to it so riv nut was also then at a angle but hole in tube
Frame was not at an angle. Anyway got it
To work
IMG 2798 IMG 2796 IMG 2794 IMG 2795
Scrappapotamus
The Scrappapotamus
799
4,323
Midway KY
  3. Talon X
  4. Talon R
  5. Talon R LV
I've installed two different sets of these. Learned a lot doing the first set
Reactions: ChadD and TxDoc
Scoop
Scoop
5,408
21,276
  3. Talon R LV
I see what you did there ... 😏
Reactions: TxDoc
