P1000 Pioneer 1000-5 Dies in Reverse.
Russ989
Russ989
22,639
147,230
Hey guys, the new 1000 started this the other day when I backed up and stopped really quick, it just died and I didn’t think much of it. It restarted just fine and I went on, fast forward to today and now it’s dying every time I put it in reverse. Anyone seen this before?
tr005
tr005
491
2,660
Big Rapids, Mi.
Haven’t heard of that yet. Did you tie into the wiring harness for reverse lights?
Reactions: Russ989
Russ989
Russ989
22,639
147,230
Is your display reading correctly. And showing the "R"?
Yes it is, it will sit at idle just fine until I put it in reverse. I’ll try to get a video of it shortly.
Russ989
Russ989
22,639
147,230
Yes I did but I used the harness light kit from Hondasxs
Reactions: Hondasxs
Russ989
Russ989
22,639
147,230
Unplug it and see if any different.
But if this was faulty the display would show "--".
Will do, I have to get back home first lol.
Reactions: tr005
snuffnwhisky
snuffnwhisky
Village Idiot
3,305
18,158
Cullman, AL
  2. Other Brand
I had the same issue. My reverse light had a ground wire but was also groundable through the body of the light so it was sending a ground signal back to the backup alarm plug. It made the computer freak and kill the motor when put in gear. You can do a connuity test between the ground wire and light body.
