P500 Picking up P520 in a week - plastic color change, plow, other questions
212,592
Another thing - I know the 520 has no turf mode. that was my only draw to the other brand. However, I can't move away from Honda. my last three motorcycles were Honda and not only resale being fantastic, never had any issue. Anyway, at very low speeds, is not having a turf mode going to cause a lot of turf damage?
Yes and no, you'll get it figured out!
LilRedDonkey
LilRedDonkey
180
614
cheesyland
turf mode!
748 P354 0000
KyGal83
KyGal83
9,612
93,537
Kentucky
Welcome from Kentucky! Like a previous comment .. I would wait on the plastic change until you receive your unit. When I bought my 500 I initially wanted a red one, but due to lack of supply ended up with a Moose Brown and absolutely love it!! The Blue May grow on you or better yet your wife.. Happy Wife, Happy Life.
The Green Goat
The Green Goat
2,434
17,929
A few thoughts:
1. The turfing isn't THAT bad, but does happen. I use my p52 for lawn spraying/spreading and am making super tight 180* turns back and forth across the whole yard. It scuffs it up in the corners, obviously, but by the next mow you can't even tell. I chalk it up to aeration. This is coming from a guy who's looking for a pristine lawn.
2. The 66" KFI poly is 1lb heavier than the steel equivalent. I haven't purchased a plow yet, but will this coming winter. After much research, I settled on the KFI poly. Its taller, less "sticky", has a $50 replaceable face, and is a smidge heavier. That said, most people seem happy with whatever plow they purchase. The KFI steel is quite popular. If I had a super long driveway to clear, I would probably lean towards an asymmetric County-style.
3. If you're looking for a cheap and not permanent color change, look into plasti-dip. I recently sprayed mine in a metallic brown/bronze because I loved the Moose Brown they offered last year. It also has the added benefit of light scratch protection for the base plastic.
20210601 213557
20210601 213612
Bigtee
Bigtee
556
1,213
Grayson, KY
A few thoughts:
That thing looks great
Reactions: The Green Goat
sleepybear
sleepybear
45
97
Montana
Has anyone measured the decibels on the 500? I have been searching the forums, I have found some things about trying to make it quieter but was looking for a general number.
wvupsc
wvupsc
180
802
West Virginia
A few thoughts:
That looks great! How durable is the plastidip when you go thru brush? Does it scratch off when limbs scrape against it?
196,132
Someone's done it, can't remember who. They sent me the readings in a PM before and after they put a shield in. Think they did it with some app on their phone. Don't remember the numbers either but it wasn't as big of a decrease as either one of us expected. Both agreed it's noticeable to the ear though.
The Green Goat
The Green Goat
2,434
17,929
It's only been on for a few weeks and about 180 miles during the recent RRB trip. I wasn't in heavy brush, but it did get some branches against it, for sure. Only scratch I can find is on the top of the bed rail and I have no idea how it got there. I rubbed something hard enough to scratch into the plastic underneath though.
Seems to handle light scuffs just fine. Anything hard enough to deform the plastic is gonna get into it though.
sleepybear
sleepybear
45
97
Montana
Is it still loud enough that you wear ear plugs or suggest wearing them? I saw one post where they put an aftermarket 'car looking' exhaust on. Think his name was Sol, he suggested hearing protection even with the mod. Sounds like your rubber mod should help with if it is noticeable to the ear. I live in the city so trying to think if I can get the noise down enough for joy rides in the yard or neighborhood without upsetting folks due to the noise. Maybe that's best suited to golf carts. I like all the versatility of the P520 but was hoping to also benefit from some neighborhood use in addition to the trail, plow, and utilitarian side.
196,132
I don't wear ear plugs, I just crank the sound system. There is a noticeable difference with the shield in as others can testify as well. I guess it comes down to how sensitive you are to the noise. Yeah, it'll never be as quiet as a golf cart. I put a Silent Rider on mine a long time ago but it robbed the machine of power so i took it off and returned it.
Reactions: Bigtee
LilRedDonkey
LilRedDonkey
180
614
cheesyland
don't know if you can get 26's, but the cheapest would be amazon, e-bay, or maybe chap moto. all depends how much you want to spend. have fun with it!!
Reactions: sleepybear
futzin
futzin
4,812
35,303
Kentucky
Looking forward to being able to spray the lawn with the 520 also. Northern tool boom sprayers? I don't have the yard to justify needing a utv, but if I have one, I am going to use it for the chores!
I have the 16 gal. Northern Tool sprayer. I like it, but kinda wish I'd gone with the next size up. The pickup is on the bottom on one side. When it sloshes it gets inconsistent spraying, even with half-ish amount left in tank. I've started just backing up, keeping the pickup on the downhill side (that actually helps with the tight-turn-burn in the turf).
I'm currently spraying an acre or two, but with spraying my neighbors' yard and some planned additional clearing, the larger size would be nice. It takes a bit to fill 16 gallons of water.
KyGal83
KyGal83
9,612
93,537
Kentucky
A few thoughts:
Great job on the paint! I have the Moose Brown and it looks exactly like mine.
Splorin
320
904
Maine
With a spooled diff scuffing is gonna happen. Plan your turns accordingly. 3,5 or even 7 point with wheels turning while steering. Been driving trucks on lawns for years. I have 26x12x12 turfs that are on my tractor seasonally but mostly for chains in winter. Not sure how 'round' they are for 35-40mph usage. I top out at 7 or 8mph....
sleepybear
sleepybear
45
97
Montana
pick up the p520 tomorrow. neighbor has a trailer i can borrow. don't think it has rails, makes me a bit nervous. maybe i should rent one at uhaul for a couple bucks for added security of rails lol.
think i will get a set of wheels/turf tires for putting around the yard/neighborhood use and swap as needed. my commercial mower has 26*12*12 turf tires, i suppose those would work well in the lawn, probably not so much on paved surfaces though. found some on amazon called SunF 25x10-12 25 which look like smooth car tires. still deciding.
