P700m4 P700 Tire Pressure for Asphalt Riding
Fatsquatch
Fatsquatch
Approved Member
120,972
1,009,094
Hidden
Pavement only….you can go with Max PSI on the sidewall of the tire. If it rides too rough for ya start dropping it down until you find something that makes you happy.
Luka
Luka
29
80
Wittenberg, WI
That sounds like a good place to start (22psi on my sidewall). What would you recommend for off-road and plowing snow, the mfg. recommended 10 front and 12 rear?
thanks.
Fatsquatch
Fatsquatch
Approved Member
120,972
1,009,094
Hidden
thanks.
There isn’t one right answer to that. I set mine at 7 or 8 in the P5 and like 5 on the 400EX. If you aren’t unseating beads and getting pinch flats you can go pretty low to gain tire footprint. But if it rides decent enough at 12-15 then run it there and you don’t have as much risk of tire damage.
Luka
Luka
29
80
Wittenberg, WI
Thanks Jeremie! I appreciate all you help. Jeff
