P500 P520 rear turn signal
F
farmer1
5
7
Ontario
Is there a simple way to add a turn signal to the rear tail lights of a 2021 Pioneer 520 using the existing lights? I don't need a full kit with front signals. It would be nice to throw a blinker on when travelling together when a turn is coming up.
Thanks
crewcabrob
crewcabrob
1,029
4,040
Omaha
Not that I'm aware of. I've been adding turn signals and a horn to my P520 so I can plate it sometime in the future.
You can buy the kit from the site store, and would have to hook most of it up so you could have the switch and blinker module. Might as well drill the holes and mount the front lights while you are at it.
Rob
67,901
I have several - 2021, 520 kits that were misordered by a guy and then canceled.
I will cut a smoking deal on them to anyone who has a 2021 Pioneer 520.
I send you a message @farmer1
Open to anyone else also that has a 2021, 520.
Just message me.
It is the Full Sequential Kit -
OlYeller15
OlYeller15
192
1,171
Thanks
A simple fix is a bike wireless blinker kit. Very reasonable and easy to install. Amazon has several different options.
L
ladoredb
50
364
ONTARIO
Just message me.
Assume this will this work on 2022 520, or did something change in wiring ?
TexasLineman
TexasLineman
Conroe
Just message me.
I'd like to know myself.
Dj2833
12
Suffolk County, NY
Thanks
Thanks
Thanks
Thanks
Hmmm not sure but a 3rd option to this approach or the kit approach is wiring it yourself-what I did on my P500. So the black toggle switch (on/off/on 3-position) is my turn signal “lever” and lights the arrow LEDs. The rocker switch labeled “Driving Lights” (a 2-position on/off switch) turns on/off the front & rear marker lights for driving at night. I used a flasher relay wired to a 4 pin relay and inline fuses (or in my case a fuse panel). Find a key-on power source for your model. The 3 position toggle switch is marked #7 in pic of switch panel rear view.
32458A14 E6B0 48DC 9D78 907F163EDF3E DA2C7FDA 9352 41D1 B320 AF0B465722A4 490E3ACC 824D 4252 B2EB 23DA0A402DCA B1A0E8F2 2750 4AD4 9C67 D693B79041AD 7C882EBE B3C2 4BEC BB8E 7AB96FE0CDD3
P
pappyo
613
2,451
Thanks
1st. Welcome from central upstate N.Y
Many good people on the Honda forum AND they LIKE PICTURES.
Red was the 1st color all other colors followed Honda hope's they sell.
Now for your question:
Simple YES
NOT USING OEM Lights. ( alot Less time & effort )
Golf Cart Signal Kit includes every you will need <-> $40.00 & up <-> Some INCLUDE 4Way Flasher / Horn & Interxior light options
Mount the lights each corner of ROOF (up out of the way easily Seen <> requires 3/4in. Holes )
Locate & install <-> Switch & Relay
Hookup the - "fused" - Pos & Neg Power feed <-> secure all wires <-> DONE
OEM Honda Roof is easiest
Other hard or soft roofs / Roll Cage <> will work just takes alittle more effort & fabrication to install lights.
Not exactly what you asked for although is Simple /Easy
F
farmer1
5
7
Ontario
Thanks for your replies. It's really helpful. To summarize, if I want to use the existing rear lights, I'm best to order a kit. If I want to add more lights, then several options from kits to assembling myself.
Haven't done anything yet, but like the idea of using the existing lights at the rear.
Reactions: Remington
