P500 P500 high compression piston
Motoman13
19
120
Indiana
I found a high compression piston for the p500 from wossner. Takes the stock ratio of 9.5to1 to 10.5to1. I looked around the forum and see no talk of this part yet. Anyone have any insight into this? I’m thinking this will be the way I’ll go. Also thinking about possibly decking the head if there’s enough piston to head clearance, just to help bump compression and increase squish a touch more. Any thoughts or knowledge on such a setup would be appreciated.
Jason W
Jason W
The Ginger Cracker
1,282
10,785
Western NC mtns, Marion
  1. Talon X LV
Sounds like a ton of work for little pay out, idk.
Then can the rod handle it, will the fuel trim be able to adapt. Modern Internal. Combustion computer controlled engines are best left alone unless your a damn good programmer in my opinioun.
Motoman13
19
120
Indiana
So I should also say I tore it down because I have to do a cam chain replacement and needed to get the cam followers out so they didn’t fall down into the bottom end. Only reason I’m even considering this. I was totally fine with it stock. I just decided since I had it tore down I’d give it a freshen up. It’s a lot of work just getting to the darn chain itself.
DRZRon1
DRZRon1
1,403
4,333
let us know how the high compression 500 turns out.
there is a reason there are no posts about this setup
Reactions: Buckaroo41
TwoTonNewt
23
115
Northwest Arkansas
How many miles/hours you got on it to need this?
Motoman13
19
120
Indiana
Just a quick update on this piston setup. It’s been an excellent upgrade. I’ve managed a couple hundred miles so far this summer on this setup. Motor is still strong with a touch more grunt. Not a lot but definitely notable. Fuel system has been able to adapt to this setup with no issues as well. Over all I’m very pleased with the outcome.
