BRed Oil drain plug where is it
rasorbackqq
25
29
Springfield NS Canada
  1. Big Red
Oil light is on and finally a little winter cold break to do it. Have the manual Thats useless....
Where is the drain plug I seen a torx head bolt on the front right of motor It doesn't line up with any holes though.
After searching the net I do see the filter from bottom through the access hole.
Can anyone assist me?
283,016
There wasn't an oil change guide for the Big Red MUV but the Pioneer 700 has the same power plant. The oil drain and filter should pretty much be in the same place, just the frame will be different. Hope this helps.......
P700 - Honda Pioneer 700 oil change guide
rasorbackqq
25
29
  1. Big Red
Done !! All some one had to say was the drain is at the back of the motor.
Hopefully the next person that goes looking for it will read this.
Its at the back of the motor under all the mud and leaves.
I wasn't looking back there as I had the driver seat, center console and half the floor out as per the maintenance book pictures.
The book did give me the picture of the washer location and spring as I seen something fall into the drain pan.
