P500 Noise going slow down hill
Chuckie3
216
408
New Fairfield ct
P-5 started making noise going slowly down hill when using the brakes,but it’s not a brake sounds like gear noise.shifts fine otherwise no problem any ideas.
silvertrd09
silvertrd09
357
1,927
Texas
What's the noise sounding like?
Chuckie3
216
408
New Fairfield ct
Sounds like gears grinding but shifts fine runs great except for slow down hill on brakes.when I go down hill slow with out brake it’s fine 🤷‍♂️
5,691
26,054
What year, how many miles, muddy or sandy riding environment? Maybe time to inspect the brake pads.
Reactions: Remington
Red500
Red500
6,417
69,220
Greeneville, Tn.
I agree with checking your break pads. I had tiny rock get caught in my rear breaks that was making noise when breaking. It didn't come out till I changed the pads. After that it went away.
KYhillbilly
KYhillbilly
562
1,713
Ashland, KY
mine does that from time to time going down really steep hills when using the brakes. I replaced rear pads and put synthetic gear oil in front and back still will occasionally do it on really steep hills. I just quit worrying about it as nothing seems to be wrong with the machine. I think it is just the design of the brake on the rear drive shaft vs on each rear wheel causing the noise. Only on really steep downhill decents.
silvertrd09
silvertrd09
357
1,927
Texas
I've "heard" noises that may be similar to what you're saying. Can't remember if it was going down hill or not. I haven't been out west since January. But I do remember I kept riding and Pockets kept rolling on. Hopefully just a rock in the brake pads.
happyfred
happyfred
57
270
NY
Mine has done the same. Usually after it has been sitting undriven for a while.
Seems to go away with use.
