P500 No spark intermittently
Daryl2
6
Australia
Hi everyone. I have a p500 18 months old. For the last 6 months it has been intermittently stopping after about half an hour of use and when idling it just stops and has no spark at the plug. Leave sit for 5 to 10 minutes and it always starts. The frequency of the stopping is getting to the stage it will only run for a couple of k’s, about 10 minutes from cold to when it stops. Have had back to dealer several times and it never stops for them and they can’t find the problem. Honda Australia no help at all.
hoping someone out there has had similar problem and can suggest what the fault could be. The vehicle is always serviced but the dealer at the required intervals. Hope someone can help. Thanks
906UP
906UP
14,984
142,369
da Yoop
My first thought is a ignition coil problem.
hondabob
1,316
5,223
Prescott Valley, AZ
Replace the spark plug cap and spark plug, next would be the ignition coil. Check all the grounds. The stator/ pulser coil would be last. With it running you can lift up the spark plug cap a bit to raise the firing voltage and it should jump around a 1/2" gap.
Reactions: 906UP and HUCK
HUCK
HUCK
1,047
2,319
ARIZONA
Exactly what HondaBob said .
snakeriver
272
596
Clarkston Wa
I have not experienced this issue on my P500, however when I worked at the Honda dealership we saw a similar issue on the 3 or 4 Forman fourwheelers, in the cases that we saw this in it was an ECU issue after the unit was ran for a while. Keep in mind that this was several years ago, and Honda may have corrected this problem.
lee
lee
Village Idiot
2,443
13,833
Springfield Ohio
I think your holding it upside down.
Sorry couldn’t resist, lived in Alice for a spell (Dad worked at the space base).
For electronics they have a spray can of ‘cold’.
It cools a part off so you can see if that part is the issue.
Not sure if this will work for something as large as the ECU or the coil.
Also might check the grounds and clean the ECU connector.
Other than that, maybe @HondaTech will have some practical insight.
