No brake lights but i have tailights
msr123
7
19
Iowa
I have a 2022 honda talon 1000r and I currently don't have brake lights I have tail lights.
6 months ago I did put it a turn signal kit that was plug and play and everything worked just fine. I recently just replayed my brake switch and thar didn't solve the issue. I have also adjusted my brake switch and that did not work. Any help would be greatly appreciated.
116,510
Welcome from the commie state of Michigan!
First things first when u join/first post so we know your not a Poo Poo Infiltrator tryin to mess with us!
Post pics of your rig!
Pics Or It Didnt Happen!
while we wait for those pics, check your fuses with a multimeter on ohms and not the tone. physically check them with the meeter and look at them even change them they are cheep. Have had Alot of fuses lately that look good and were actually bad. Also what brand turn signal kit?
Red500
Red500
6,501
70,036
Greeneville, Tn.
Fuses and relays is where I'd start.
Welcome to the club from East Tennessee.
Reactions: Scoop
21,710
92,774
Disconnect the turn signal kit and see if you have working lights.
Could be many things.
Faulty light assemblies, faulty TS light controller, bad wiring somewhere.
How did you diagnose a faulty brake switch?
msr123
7
19
Iowa
I have disconnected it and that wasn't the issue. I started adjusting my brake switch and when I did that sometimes it would take put my tail lights so for 18 bucks that's where I started.
Reactions: Scoop and Red500
116,510
Why where u adjusting the brake switch?
And what is the last part your saying? I dont speak Japanese! 🤣
Wheres the pics? 🤔
  • Haha
Reactions: Scoop
msr123
7
19
Iowa
Wheres the pics? 🤔
You can tighten or loosen the brake switch, so I tried that, 18 bucks is what a brake switch cost.
20230204 120050
21,710
92,774
Do you have a service manual?
Disconnect the TS convertor at the back. Check the Honda wiring for signal when brakes are applied.
If signal is there, remove TS convertor and plug Honda wiring back in.
If your turn signals currently work. Everything from the TS convertor back is working correctly.
Talon lights are 3 wires.
Ground
Running light
Brake light (also turn signal)
