P700 New Custom Snorkel
SuperYeti
SuperYeti
220
375
Vancouver, BC
Ok as promised....
Got everything finished, and put back together tonight.
Attached the lower intake coupling to what's left of the stock intake.
IMG 20160118 123347 zpsjegcgwwy
Then installed the lower portion
IMG 20160118 125516 zps0dkkmhws
A little bit of cutting to get around the snorkel
IMG 20160118 130316 zpsdblxcj51
Nice fit!
IMG 20160118 130459 zpszjz2gwse
Unfortunately since I had already cut some plastic for the other snorkel design, there's a bit of a gap....I guess i could replace the piece some day, but it really doesn't bother me that much.
IMG 20160118 134414 zpscbnclrrk
Here it is all put back together I just have to grab 2 gear clams for the scoop to attach to the RPS, and it's good to go. Started right up, and I must say, it's WAY quieter than the previous ABS one, I can't wait to get out and test it soon.
IMG 20160118 125504 zpsoxupsfgv
IMG 20160118 134553 zpsfr0r10ud
Reactions: allgm1 and Tflynn
SuperYeti
SuperYeti
220
375
Vancouver, BC
Ya, now I just have to wait for the baffles from China Post......Once they arrive, in they go, fuel tank vent, and ready for submarine mode lol.
Reactions: Tflynn
d_b
d_b
302
240
Whats the update...
SuperYeti
SuperYeti
220
375
Vancouver, BC
The bellows showed up this week, will be installing them this weekend and taking everything for a test ride next weekend.
allgm1
allgm1
1,049
1,485
New Hampshire
I'd like to see video of your submarine in action, pictures just don't do it justice.
SuperYeti
SuperYeti
220
375
Vancouver, BC
May have to settle for whatever snow I can find, which could very well be submarine depth lol. We have a huge storm rocking through right now and the freezing level is about 3500' there should hopefully be some good snow next weekend to play in.
SuperYeti
SuperYeti
220
375
Vancouver, BC
Well finally got out and did some testing with the snorkel today, it worked awesome! I wasn't planning on going submarining so I didn't get the bellows installed on the diffs and sub-transmission....Guess I'm changing all fluids this after the weekend now... All in all, super happy with the snorkel, after it sitting for 10 minutes off like the following while we setup to winch me out, and then playing in that deep or deeper water for another hour, only had a few droplets of water in the bottom of the airbox when I got home and checked. Next to finish up the bellows, and figure out what a kit's worth and if there's any interest.
Got hung up on the big truck ruts :(
IMG 20160325 161730 zpskjufr2uf
IMG 20160325 124724 zpsxk9tsrq0
IMG 20160325 124708 zpsrut7lcv7
The next 2 pictures were a fiasco lol. The other side of the washout/deactivation ditch you can see there had a big rock, and then a couple feet above that had a big slippery log still embedded in the bank from the old bridge. No matter what I tried I couldn't bounce myself up it, and couldn't back out, nor could my buddies ATV winch get me out, so I ended up doing a 15 point turn at the bottom of the gulch, got it this far up, then was able to winch myself out.
IMG 20160325 114244 zpsumsykday
IMG 20160325 114235 zpslqatc1hj
That looks like a mess!
SuperYeti
SuperYeti
220
375
Vancouver, BC
Quick update, been running the rig hard on a few hunting trips, and other runs, and everything's been holding up really well. Went to install the diff bellows, and they're quite a big larger than the nipples, going to need to come up with some tubing, and couplings to get it to the right size. Any suggestions where to find that, and the spring clamps? Nowhere locally has anything. Also I've been noticing a bit more noise coming from the intake, i suspect part of it is reverberating off the roof, and now that it's a clean clear shot to the airbox I'm hearing a lot more of the intake noise when at WOT. I was thinking maybe welding in a couple baffles in the intake that should also help keep water out, and block the sound waves from making it out, it will restrict airflow a little more, but I'm open to other suggestions heh.
Reactions: Tflynn
Vato
Vato
180
159
Might be a bit loud in the cockpit with intake above your'd head but it's way better than sucking water into your engine.
Run your intake scoop outside the cockpit.
Vato
Vato
180
159
Nice fabrication!
SuperYeti
SuperYeti
220
375
Vancouver, BC
So after being annoyed, and having a few of the back seat passengers complain about the noise, I did some research. It seems the common way to fix the intake impulse noise is to put a grid into the intake, and the theory seems to be the smaller spaces break up the sound waves. So last night, I decided to rectify the problem. First I took some 1/16" steel I had laying around, cut into 1" x 3" strips, and then flipped 1/2 of them and cross cut them to fit into a grid.
IMG 20170920 201413
Tacked everything up and then tested with and without, a small difference at idle, but WAY less noise revving the engine
IMG 20170921 190827
Then went for the extra trick tube sock pre-filter and it got even a bit quieter, and should help a bit more with dust
IMG 20170921 191302
