P700 New Bed Rattle Fix
William
William
1,442
2,889
Flowood MS
I am pretty proud of this fix I came up with... Bought a thick bicycle inner tube and cut it to length.Put it over the latch and fold the excess over (you want the excess)... zip tie it tight and no more noise! When you dump the bed with this on you need to hold the dump latch up when you put the bed back down or the other side will cut the rubber... works great!
488D41ED 6507 47CF B857 120BFC043CD3 247FF320 F531 4B2D 8041 3A1E004E4C2F
William
William
1,442
2,889
Flowood MS
This fix is still going strong... made it through a few weeks of deer hunting with no noise.
Reactions: Russ989
Marc1991
Marc1991
56
194
New york
View attachment 97374 View attachment 97375
Genius! Any ideas for the doors? The driver side isn’t too bad because my leg usually rest up against it, but the passenger side is brutal.
William
William
1,442
2,889
Flowood MS
I jb welded a thick piece of rubber to the door stopper to give me more adjustment. Basically made the stopper longer. Worked great.
Beretta67
Beretta67
37
137
McKean Co. Pa.
i Wrap some cheap electrical tape on the door striker It lasts a while, once it starts rattling again I remove & repeat.
Marc1991
Marc1991
56
194
New york
That’s what I’ve been doing. When I’m using the machine for work I get in and out a bit and it wears out quick , so I’ve been looking for something more permanent. The idea of extending the stopper is solid.
Backwoods
Backwoods
37,750
376,085
Douglasville ga
Go to Walmart buy the ends for round chair legs it fixed mine for good for less than two dollars. Put them on top of the Honda stoppers.
rickoshea
i've been doing both on my 1k for several months now.i use a truck tube,but it wears out after a while,especially the bed and drivers door, so i just repeat the process.the chair leg pads i stuck to the body and they've not been needed to be replaced.
Reactions: Backwoods
212,710
Pictures?
