Ragincajun92 Active Member Mar 19, 2018 163 231 43 Kingsland, Georgia Ownership 500 Mar 25, 2018 #1 The Honda pioneer bolt pattern is 4/110 correct? Also when ordering rims you want 5+2 for front and rear correct or do does the front take a different size?
Admin HondaSxS.com Advertisment trigger Old Ironsides Vendor Lifetime Member Supporting Member Feb 13, 2016 26,572 195,200 113 Bay City, Michigan www.quickshieldutv.com Ownership 500 Mar 25, 2018 #2 4/110 is correct. 5+2 offset front and rear. Heads up, you're going to need splined lug nuts. Reactions: Chooglin and Ragincajun92 Ragincajun92 Active Member Mar 19, 2018 163 231 43 Kingsland, Georgia Ownership 500 Mar 25, 2018 #3 trigger said: 4/110 is correct. 5+2 offset front and rear. Heads up, you're going to need splined lug nuts. Click to expand... When I order the rims it says it comes with lug nuts so they should know what I need hope Reactions: trigger and Chooglin
