Need Some Packout Feedback
Fatsquatch
Fatsquatch
Approved Member
120,627
1,006,970
Hidden
I took that combo off of this buggy. A very popular setup but it's not for me. Will be selling them, along with some other stuff off of it. Tires/wheels, sound bar . . .
I guess I could offer all three for sale as a combo: Rotopax, box, rack.
👍🏻yeah I wouldn’t keep the combo of the three mounted like that either.
futzin
futzin
4,741
34,765
Kentucky
I'm reading that the Large Wall Mount Plate (triple) is not fully compatible with the boxes with the silver bars at the corners (like Green Goat had pictured). They overhang the third set of mounts.
21,715
92,834
Correct. You can put some single ones beside them, but it is a pita to install/remove them.
futzin
futzin
4,741
34,765
Kentucky
That's gorgeous, Bear!
Fitment isn't really an issue; plenty of space. Just basically trying to decide how to attach the bases (and which ones).
As of this writing, I'm thinking Honda tray with the bases attached to it and to the buggy's rack and/or flat bars attached to it.
I'm going to camp this week; I'll bring back the tray from Critter and play around with it. Prolly pick up a base from Hom Deepo to mess with also.
futzin
futzin
4,741
34,765
Kentucky
So after playing around with a Honda tray and a Packout base, I'm thinking I'll go with two PO bases bolted to the tray only (maybe find a couple of spots to through-bolt to the rack). There are 12 points on each base to bolt to the tray, and the tray is rated to hold 420 lbs. What could go wrong, right?
The contours of the tray will make it interesting, but I think I've got a pretty sturdy layout ready.
Unfortunately, the 4gal rotopax and mount will have to go. Doesn't play well with the Honda tray. Works ok with a vinyl rear panel, but not really with both I'm thinking. Too bad, nice location for 4 gallons. (I need to put together a for-sale list for TO)
futzin
futzin
4,741
34,765
Kentucky
Anybody know of somewhere with Honda accessories discounts? :) Might also be needing a Honda windshield and rear panel.
The Mrs. is starting to balk . . . took longer than I expected, frankly.
Smittyp
Smittyp
664
4,506
Morgan co. Tennessee
If you decide to sale them individually I’ll take the 4gal rotopax and mount
Fatsquatch
Fatsquatch
Approved Member
120,627
1,006,970
Hidden
Ronayers is the one I always price shop against. It’s not always the cheapest but it is consistently cheaper than others. My local dealer is unfortunately an MSRP type of place for parts so I buy very little there anymore.
lee
lee
Village Idiot
2,441
13,821
Springfield Ohio
I'd like to think the honda windshield is genius but it dose not open very far.
The SuperATV windshield really has superior air flow ideal for hot humid southern riding.
The honda allows for easy access to under the hood.
And it is better protected if you tip over (because it doesn't move very far).
Kind of trade offs either way.
I'd bet the guy who designed the honda one would chose the SuperATV windshield.
I don't have any idea how to fix the other issue.
futzin
futzin
4,741
34,765
Kentucky
I have two of the Honda windshields; I like them. The tilted position has enough air flow for me, and no fuss to get under the hood, as mentioned. The hard coat, I've learned, is a must if you're trail riding the machine.
The side rubber pieces like to go hiking though, too. ;)
The SATV model, when open, looks vulnerable to SPIMs, but maybe with this machine at 60" that won't happen very often! Maybe . . .
I'll give that one another look.
futzin
futzin
4,741
34,765
Kentucky
Here's a few pics, some of y'all seem to get irritable and sleepy without them . . . words are hard! 😅
If someone wanted to mount directly to the rack you can get, I think, five bolts directly in. Lines up pretty well, really.
20240316 161532
This layout is also a possibility: one 'double' mount in center, with one 'single' on each side.
20240316 165224
But I think I'll likely go with two 'double' mounts, bolted to just the tray (which is pretty darned thick, actually) with stainless hardware.
20240316 185632
futzin
futzin
4,741
34,765
Kentucky
Finally got the PO bases mounted.
Cut up a couple of Simpson flat plates to span voids. Ain't proud of it but should stay put. Stainless hardware.
20240401 15290820240401 163304
Gotta choose some PO items now!
futzin
futzin
4,741
34,765
Kentucky
Looks great! Now go get it dirty!
Gettin' close. Need to finish up the front skid piece and then see how well the nerfs are gonna play (or not) with the SSS skids. A few other odds and ends, then I plan on putting on a set of my 27s for some light testing. At this point, I'm thinking 28x10x14 Evolutions on a 6+1 offset wheel.
TxDoc
TxDoc
2,252
7,532
TEXAS 🇨🇱
photos.app.goo.gl
Looks great
May have to duplicate that so that one can be immortalized in a climate controlled garage and covered so not even dust can cause it to become tarnished.
And, the backup one can be taken anywhere and subjected to the most horrific conditions and situations without any chance of triggering anyone or causing unnecessary mental grief ..... Or maybe not.
Great rig and customization
Sent from my motorola edge plus 2023 using Tapatalk
