P500 Need Help - Light Bar Install
futzin
futzin
4,741
34,771
Kentucky
I bought a 12" lite bar (36 volt) that did not come with a switch, which of course I'll need to buy.
It has two short wires supplied. Utilizing the Honda harness, what else do I need (wires) and a crude diagram for this electrical noob would be greatly appreciated!
Buggyman
Buggyman
47,888
375,889
ne. ohio
no expert by any means but fwiw mine came with wire heavy enough for the length of run based on max amps, inline fuse ,relay ,switch. one of the wizards will help with a diagram
68,146
That would be fine. Adding in a 10 amp fuse.
Most don't like this because it is directly wired. But it's fine for small draw items.
Assuming you mean 36 watts... not volts.
If the package says 36 watts. Then a 5 amp fuse is what you should use.
futzin
futzin
4,741
34,771
Kentucky
Auxbeam LED Light Bar 12" 72W Driving Light with 3W 24pcs Chips Combo Beam Waterproof​
tem Dimensions LxWxH16.14 x 3.94 x 3.94 inches
BrandAuxbeam
Color12inch combo
Vehicle Service TypePassenger Car, Bus, SUV, Truck
Voltage32 Volts
Light Source TypeLED
PositionFront Outside
MaterialAluminum
Water Resistance LevelWaterproof
Remote Control Included?No
Reactions: crewcabrob
futzin
futzin
4,741
34,771
Kentucky
Power: 72W
Number of Chips: 24pcs*3w high intensity LEDs
Operating Voltage: DC 9-32V
Luminous Flux: 5040lm~7200lm
Beam Type: 30 degree (spot beam) & 60 degree (flood beam) combo
Color Temperature: Pure White 6000K
Waterproof Rate: IP67
Working temperature: -40~85 degree centigrade
Dimension (with bracket): approx. 302*106*64mm/11.89*4.17*2.52inch
Material: Black Diecast aluminum housing, PC lens
Mounting Bracket: Stainless steel bottom bracket
Above 30,000 hours life time
Certified by CE & ROHs
68,146
Ok. Its 32v max.. Just making sure it will work with 12v.
One guy I dealt with bought a 24v only light. I never seen one like that. It was actually for some industrial equipment. He was SOL.
