P500 Need help!!! Fuel pump fuse?
Newfiebullet
Newfiebullet
82
187
Labrador, Canada
So I got my bike stuck today while plowing, it was up a pretty steep hill.
I ended up leaving it for 5-6 hours there because I had other stuff to do.
Just went out with my snowmobile to haul it out and it wouldn’t start. I figured where it was in a hill.... I hooked on to it and got it level.
When I turned the key no fuel pump kicked in, and the dash wouldn’t light up, I flicked the key a bunch of times and got the dash to light up but still no fuel pump. I tried it anyways but no go.
Took a little break to do some reading up on it and now the dash won’t light up again. Fuse? Relay? Is this because it was left on a steep angle for so long? Anyways I have no idea where to look.
Any ideas? Thanks
116,524
Check for broken/corroded eire. If all good and fuse is good, check power with a meter at the pump with the key on. If u have power that eay, u have a pump issue. If no power , u have a connection issue. Good luck
Reactions: Mudder
NTC/TAP Transition Member
11,835
90,083
These are very sensitive to low voltage. Been there. Will make you scratch your head. Plowing then stopped before time to recharge?
11,835
90,083
These are very sensitive to low voltage. Been there. Will make you scratch your head. Plowing then stopped before time to recharge? Fuel pump relay is the square upper left of four.
