Man, Every 1200 Miles Comes Up Fast
Bighat
Bighat
908
3,865
Gallipolis Ohio
Seems like I just changed the oil in this thing. Coming up on 3600 miles and almost ready again. Do these things really need an oil change that often? I'm running the Honda synthetic oil. It looks clean when I check it. I mean my street bike is every 5000 miles. Isn't this engine a large bike engine? Just wandering what everone else does.
Street bike isn’t in the dust and grime though. I’m horrible at maintenance but on this machine I would suggest to change oil by recommended intervals or at least close. It’s a spendy engine if it were to have issues, plus transmission is linked to it.
212,797
It's because of the clutches using the same oil as the engine?
Scoop
Scoop
5,438
21,385
  3. Talon R LV
While the engines are largely similar, the environment in which most operate a SXS vs a street motorcycle aren't the same.
Oil & filters are relatively inexpensive and changing any of it is not difficult at all. I sleep well.
If you're particularly anal and want to know what's going on inside your engine, you can always send a sample to Blackstone Labs for analysis. I did that religiously with my F350 Super Duty Powerstroke, but that was a significantly larger investment that came with the potential for a significantly larger repair bill if you didn't pay attention ... and far more expensive oil changes.
212,797
Exactly. I'm way under the recommended oil change intervals because I don't want to go over while on vacation.
hondabob
1,320
5,252
Prescott Valley, AZ
The oil changes come up fast for me, I'm over 8,000 miles on my 2020 Talon and getting close to 38,000 miles on my 2019 Talon. I change the oil on time and use full synthetic. Both still run like new. It looks like if maintained properly these engines should go to around 70,000 miles before major repair is necessary.
116,574
@Bighat I suggest what @Scoop said if u really want to know what your oil is like at that mile interval and if its worth changing then. Of corse the environment its in, how good your air filtration is makes the difference but everyone with that is different. I did this with my 16’ P1 cuz of the environment its mostly in now (farm rig) and my oil breakdown (blackstone) i use Rotella T6 since second oil change, Is 1/2 broken down as before in the same milage. Im roughly every 2k now just for spite on the P1. Also dont go by date vrs miles, bunch of BS unless its years lol. Again, everyone is different. Send it in at this milage your at and find out. Come back and give us the results.
Racerhed
Racerhed
660
6,550
Ashland OH
  2. Talon X LV
These things take oil?? I swear I just pour cash down those little holes😜
I’m contemplating sending a sample in to see what the report says. Anyone know if they check for dirt while checking for the different metals?
  • Haha
Reactions: Smitty335 and CID
5,759
26,451
Remi nails it. Our individual riding conditions vary wildly and analysis is the only way to know. I haven't done it yet and know I should.
fwiw: I've upped my change intervals to 1500 miles
1698758021927
because those increments are easier for me to remember and I 'usually' ride like an old woman. I should have switched to T6 (full syn) then but already had dino on the shelf. I have T6 on the trailer right now and my future changes will be T6. Full syn 'should' cover those extra 300 miles safely. IMO, YMMV, yada, yada, yada.
tjoreo
tjoreo
1,032
1,992
Southern Idaho
I came from the 700 to 1000 which the 700 recommends changing every 600 miles. To me oil was cheaper than the headache it could cause, so I actually changed the 700 at every 400 miles. When I got my 1000 I figured I would do it every 600 miles just for cheap insurance. After about 4 changes the oil looked very clean at this interval, so I've went to every 1000 miles. I figured it was easier to keep track of.
5,759
26,451
I'm pretty sure they do, dirt shows up as 'silicates' if I remember correctly.
Reactions: Smitty335 and Scoop
Scoop
Scoop
5,438
21,385
  3. Talon R LV
Silicon.
Of course, while that will show up, these analyses are really for tracking how and why your engine is wearing and what is wearing, based on all the various levels of elements in the sample.
Attached is a sample report from Blackstone Labs for gas/diesel engine oil analysis, including a basic explanation.
  • Understanding-Engine-combined.pdf
bigshoe
bigshoe
422
1,427
I do more oil changes in a week then most do in there lifetime, I know dirty oil. I change both of mine every 2k and its still not contaminated. the p1000 filters dct oil before its dumped back into oil pan to be filtered again, so there's slim chance of clutch fiber getting into oil. I get oil for free and still won't waste it every 600 miles
Bighat
Bighat
908
3,865
Gallipolis Ohio
You've got to be right because my oil looks super clean every time I change it. I know a lot of it is I'm not riding trails eating someones dust. It's mostly on pasture, blacktop and gravel rodes. If you were riding in dirt alot, then yes, you would need to keep and eye on your oil and change it more often. That's probably how Honda has come up with this schedule. Most people are more likely riding these things for sport and therefore in a much more dirty enviroment.
Sport is an overrated term. I like to consider it a thorough punishment towards the woods.
