Light(EPS) No Power Steering
Shako1921
tbilsii
hello ,
after washing my Honda Talon SXS1000R 2021, EPS light is on and i dont have power steering, i have changed EPS Module 2 times and still the same problem , if someone has any idea let me know please, unable to make diagnostics, i am very far from such service.
5,727
26,211
Welcome from America. Thanks for posting your location, you are, indeed, far away. :oops:
Someone will be along shortly with some suggestions on where to start troubleshooting. Hopefully, whatever got wet will dry out and your power steering will start working again. But that won't help if it happens every time it gets wet. :(
Post up a photo of your Talon, everyone loves buggy photos. :cool:
Here are a couple of useful Talon information threads -
62,346
hello ,
Might be a stupid question, but have you checked the fuses?
Shako1921
tbilsii
yes, i have checked Fuses, everything is fine with them . i have checked positive wire is good which goes from Battery into the EPS module.
Reactions: Remington and CID
5,727
26,211
If you have an air compressor, you could unplug each power steering harness plug and blow it dry.
Reactions: IDIOT
Shako1921
tbilsii
i have washed it 1 month ago, i was waiting for 2 weeks for new EPS module, after recieving , i thought module which i have recieved may wasnt in working condition and i have purchased new one, recieved second module yesterday ,and it still doesnt work
  • Sad
Reactions: CID
DRZRon1
DRZRon1
1,401
4,326
down to checking powe/signal wires for voltage/ground/shorts etc - it’s not the module
Shako1921
tbilsii
how can i check it can you explain little bit more please if you have time for that
DRZRon1
DRZRon1
1,401
4,326
pull wiring diagram and start checking every wire that goes in and out of the ps unit check continuity end to end and from each wire to ground for a short and of course visual inspection
and please triple check fuses, all connectors are plugged in correctly - etc., basics
hope this helps
116,537
hello ,
Welcome from the USofA
Need pics posed of your rig please! POIDH
You have 21’ talon. They have horrible EPS and dead steer. Instead of farting around with this, do yourself a favor and go to SuperATV.com and buy there updated power steering kit. You will be much happier!
Problem solved
Reactions: Bad_bowtie
PhilCod
PhilCod
363
755
Indiana
Good info on the SATV PS kit. I have a '20, PS is a little sluggish, but I need new tires, so that may be part of the problem.
DRZRon1
DRZRon1
1,401
4,326
what size tires are on this beast?
so I this fixed, yes or no?
if it is fixed, what did you find that ir had no power steering?
fyi - new tires will only make the PS worse IMO as they are gummier\stickier\not rounded. new tires will not fix a power steering problem if it still exists unless in the rare case going to smaller tires.....
good luck and can u Kindly post pics of the beast?
PhilCod
PhilCod
363
755
Indiana
System 3, 30". Last time I had the Talon at the dealership they felt the PS was okay.
