I have a viper winch and it was super easy! Two wires from battery to solenoid (red/black) then two wires from solenoid to winch( blue/yellow). And then the red "key on wire" plugged into the harness via bullet connector.Thanks for your patience! I placed an order and will have it by Wednesday.
I will try to post some pics so others can learn from my adventures.
Here's a picture of the wiring diagram that comes with the Winch...
I was told to purchase this Part number for the mount: 2202918 you can get it at amazon for about $80Does anyone know if the Terra 35 bolts right up to the stock bumper, or is a AM mounting bracket needed? If so, which is the best, simplest to install?
Thanks dmc, ouch, half the price of the entire winch set up!I was told to purchase this Part number for the mount: 2202918 you can get it at amazon for about $80
So now that I have the wiring harness- which wires do I attach to?I have a viper winch and it was super easy! Two wires from battery to solenoid (red/black) then two wires from solenoid to winch( blue/yellow). And then the red "key on wire" plugged into the harness via bullet connector.
I did need to swap the cables to make it work because the yellow/blue were longer than the red/black to reach the battery under the seat all to the winch
There's yellow, green, white & Red.
The wiring from the rocker switch only has the red- So I would assume red to red?
