P1000 Kemimoto Universal Signal/horn kit
CJQuig
CJQuig
79
215
St Johns, Nl, Canada
Reactions: TxDoc
CJQuig
CJQuig
79
215
IMG 3544
Reactions: ChadD and TxDoc
Hillbillytnt
Hillbillytnt
559
2,053
Ky
If you have a second fuse box run it through that. It’s not that smart it won’t know the difference
116,529
Hey,
I purchased the "KEMIMOTO UTV Turn Signal Kit, Universal UTV ATV Street Legal Turn Signal With Rocker Switch & 110D Horn, Plug & Play Blinker Kit Compatible With Polaris, Can-Am, Kawasaki, Arctic Cat, CFMOTO, Pioneer" on Amazon.ca (not .com), there is a difference. Canada's is more expensive... It is to be hooked directly to the battery, How should I install it so that it will not drain the battery?
CQ
Jesus! Had to get my bifocals out to read this post😂
Should have just bought the kit from the club store, wouldnt have this issue imo
116,529
You need a key on sorce. There is an easy connector in the club store as well. Or start poking around the rig to find one. I know youll hate this, but in the search there is alot of threads for various ket on sources.
In My P1K5 build, early in 16’ before the bossman made it easy for ya’ll with a molex pig tail, he showed the key on source to splice into under the dash. U will have to go into my build to find it with the pic. I cant remember enough cuz it was 5yrs ago to tell u where its at. If I had a new rig tho, Id get the pig tail east hook up from the club store
CJQuig
CJQuig
79
215
I don't hate anything, I was using the search function...lust didn't know what to search. Thank you, Ill keep searching. What connector in the club store?
116,529
Didnt suggest you hated something! Just that youll hate it like others when we say to use the search😂
Reactions: TxDoc
Hillbillytnt
Hillbillytnt
559
2,053
Ky
The club store has the best key on power source. It plugs in to the back of your 12v port it’s clean and easy. Don’t know about getting it to Canada. If you plan on adding other accessories I’d go ahead and use to to trigger a bigger relay to draw power from.
