JJ's Talon 1000R-4 "work in progress"
-JJ-
-JJ-
17
61
Mississippi
  1. Talon R4 LV
I took everyone's advice on my previous post, sold my P1K5 LE, and joined the cool kids club with a 2024 Talon 1000R-4. Not a huge fan of the white, but a small sacrifice to make since red is the main color and everyone knows Red is the fastest color. I'm gonna make the time to build and enjoy the Talon which is something I never did with the Pioneer. Figured I'd go ahead and start a build thread since everyone likes to help others spend some money. So with that said, I'm open to suggestions on the must haves and the should wants.
20250315 102127
-JJ-
-JJ-
17
61
Mississippi
  1. Talon R4 LV
  1. Desertcraft pre-filter from 10-80 Dirt Sports (installed)
  2. Bosman front bumper direct from Bosman (ordered)
  3. Seat belt bypass from club store (installed)
  4. Custom packout mount from @-Bear- (ordered)
  5. OEM fender flares from dealer (installed)
JenElio
JenElio
80,954
708,477
Loxahatchee, florida
Congrats!! 🥳
Scoop
Scoop
5,369
21,134
  3. Talon R LV
Welcome from Michigan. Even though you got the OEM fender flares coming, you'll likely end up adding the Mudbusters as well.
-JJ-
-JJ-
17
61
Mississippi
  1. Talon R4 LV
So i take it the oems aren't quite wide enough to do the job by themselves?
Scoop
Scoop
5,369
21,134
  3. Talon R LV
Depends upon the conditions you typically ride in.
-JJ-
-JJ-
17
61
Mississippi
  1. Talon R4 LV
Currently torn between the superatv glass windshield and the assault industries glass windshield. It looks like the vents are slightly larger on the assault. Superatv has windshields 25% off right now so definitely looking to pull the trigger on one or the other. Haven't seen anyone's build using the assault but numerous with the superatv. For those running the superatv, likes and dislikes?
GovtMule
GovtMule
21,412
183,635
Tennessee
Look at MotoArmor or UTVzilla. Both have a center whole coverage wiper with vents. I got the MotoArmor, and like it. Same company.
-JJ-
-JJ-
17
61
Mississippi
  1. Talon R4 LV
Thanks Mule I'll check them out. Good airflow through the MotoArmor's vents?
A
adudes
102
252
  1. Talon X4 LV
I have the Superatv glass windshield. The grommets are junk, ripped immediately when installing. The Phillips head bolts are too long and nearly touch the plastic on the bottom mounts. I installed shorter allen heads to make removal and installation easier.
20240515 172145
20240515 172154
