How long did your stock battery last?
Red500
Red500
6,610
71,012
Greeneville, Tn.
fwiw: for the guys who use a maintainer all the time - I think it will mask an aging battery. You'll leave on a ride not knowing the battery only started the buggy with a surface charge, you'll get miles away from the trailer and it'll fail suddenly. Or so you'll think. When in reality, it had been failing for quite a while but that was just an illusion.
I know maintainers have the reputation of prolonging battery life but I'd rather know the battery can hold a charge from week to week without artificial support, that way the battery will fail in camp instead of miles out. If you have a high parasitic draw, a maintainer will hide that too.
Just my humble opinion, as you were -
You are absolutely correct, but I never ride alone, and always carry a small set of jumper cables. I know it is going to fail soon, but the longer I can wait to tell the wife I have to spend money the longer I have to live.
PJon
PJon
799
3,241
Arizona
5-1/2 years now and still going strong. I did have to put it on a charger for an hour this past summer after it hadn't been started for about 3 months. I keep a jump pack with me just in case.
EMAW
EMAW
Mama Tried!
3,680
46,379
Kansas
3 wheel bearings? You mud a lot?
Not really, we’re retired and we have enjoyed traveling to ride in multiple states….
I have no problem replacing a w/bearing, if it’s questionable or a weak battery with no parasitic draw. 21st century product production is all about quantity not so much quality! IMO
Scoop
Scoop
5,438
21,377
  3. Talon R LV
fwiw: for the guys who use a maintainer all the time - I think it will mask an aging battery. You'll leave on a ride not knowing the battery only started the buggy with a surface charge, you'll get miles away from the trailer and it'll fail suddenly. Or so you'll think, when in reality, it had been failing for quite a while.
I run 2nd batteries and an isolator on both machines. Both are always maintained and I can always jump the primary from the aux. The chance of both failing miles from camp (due to masking by keeping a maintainer on them) is likely astronomically low, and the isolator will keep a one from killing the other. Meh.
Dirtstiffs-1000
Dirtstiffs-1000
1,733
6,257
hondasxs.com
Agree, didn't think it worth mentioning.
5,756
26,439
Not everyone has dual batteries.
Reactions: Red500
Scoop
Scoop
5,438
21,377
  3. Talon R LV
Not everyone has fire extinguishers in thier homes, either. You have to make wise choices and be prepared for the unexpected. 😉
5,756
26,439
Where's the fun in that? - Safety Third - :cool:
Reactions: Red500
