Have a few accessories helper items in the works for the talon.
Most will not be live until after the takeover as I'm completing final testing there.
They are.
Also, have the following currently being sold for the Talon
Ok. Thanks.
They are.
- OEM switch plate accessory pigtails. So you can add your own accessories.
- Wired, carling style switch connectors. Just a pre-wired switch connector for the OEM switch plate.
- High beam, Light Bar relay. Hook up a light bar that works off a high beam. Saves a switch spot this way.
- Reverse trigger adaptor. Used to run an auto backup light.
- Dual battery kits.
- Seatbelt harness adaptors.
- Key-on power kit V1. Single positive wire for your accessory needs.
- Key-on Power Kit Version B for the blue plug. Positive and ground for your accessory needs.
Ok. Thanks.
