honda talon busbar with second battery install question.
johnnunez29
22
5
fl
I have lots of questions about your wiring. Hard to figure it out. and missing items (wires)
Need to discuss one item at a time to best NOT confuse things.
Let's break it down item by item.
40A bus bar kit.
Using your image. Post are in this order. 1 (top), 2, 3, 4 (bottom), Post are NOT connected to each other so each must be FED.
- Plug the 2 pin connector into the blue connector.
- Post 1 - MAIN POWER from the large OEM supplied red wire, ensure this is connected inside the battery box. Hook red wire from the 40a relay here also.
- POST 2 - Orange wire goes to post #3, can also jump to post #2 using a jumper. Now both post 2 and 3 are new 40a key-on power post.
- Post 4 will be a ground post. Connect the OEM supplied large guage black wire to this post.
ISOLATOR kit.. (not discussing voltmeter)
- Isolator MAIN post: needs main battery power so connect it to post 1 of the bus bar.
- Isolator AUX post: needs to go to the second battery positive.
- Isolator little black wire: needs a true ground. Use post 4 if you like or a screw on your fuse box negative side.
- ALSO... to complete this circuit, the second battery needs to be GROUNDED. You will run a wire from the second battery ground to post #4.
FUSE Box. (40 amp limit).
- Positive goes to post 3
- Ground goes to the second battery or post #4 will work also.
That should have you set.
You are the man! Than you sir. This is what you said drawn out. When I get back in I will confirm
IMG 0281
Reactions: trigger and JNo323
67,822
Is the way this is wired only getting power for accessories from the 2nd battery?
IDK...
But I know that black wire on the bus bar is usless. Not sure what it is.
I have found a lot of people do not ground the second battery correctly.
This causes many problems down the road. Works today.. and maybe tomorrow.. but not next month.
johnnunez29
22
5
fl
IDK...
Oh damn. I was trying to get power to the fuse box solely from the 2nd battery. Like to not draw from main battery
Reactions: JNo323
johnnunez29
22
5
fl
So is the isolator supposed to light up or something? Cuz I’m not getting any charge on 2nd battery at idle. Even if I connect trickle charger. Only bus bar gets charge
DRZRon1
DRZRon1
1,336
4,159
Depends -
Your main battery needs to be charged first before the isolator will sense and then connect the second battery and blue lite will come on
IMG 2851
johnnunez29
22
5
fl
Depends -
Your main battery needs to be charged first before the isolator will sense and then connect the second battery and blue lite will come on View attachment 459877
Either my relay is shot or my isolator is trash. For whatever reason I think it’s the isolator. I just don’t know where to find locally. And I think the way I now wired it works but the fuse panel should be getting power from both batteries. I want it wired seperate. I think if I put positive from fuse box to battery it’ll solve my issue
IMG 0285
johnnunez29
22
5
fl
spoke to the manufacturer and he told me i need to install the trickle charger at the 2nd battery, not the main. says the charge will travle bacl but not forward which doesnt make much sense, i will call him to get a better explanation tomorrow.
67,822
Trueam isolator is ambidextrous.
To test it. Disconnect one post and charge it.
Ex. Disconnect AUX post and crank machine.
Wait till the connected post reaches close to 14 volts.
Did blue light come on?
johnnunez29
22
5
fl
So I am trying to get batteries separated. The way I wired it I’m pretty sure this is running power from both batteries. So far this is what I have for a schematic. How does it look?
IMG 0290
johnnunez29
22
5
fl
I put oem as a battery just to simplify things. Avoid any confusion.
67,822
Are you sure the purple is connected in this manner? This is what a bunch of people forget to do. (ground the second battery correctly)
The yellow is pointless; it's not doing anything.... at the moment... but it could be used as a ground point in the future.
Relocate the winch to a second battery.
johnnunez29
22
5
fl
I believe that is what the isolator calls for. I was considering running the winch off battery 1. Still think that’s not a terrible idea. The ground on busbar asks for it in their instructions
67,822
It's missing the adjoining wire.
So at this moment, it does nothing.
Leave it.. or remove it. doesnt matter.
As long as it is wired as the image, consider it a future ground lug.
Reactions: johnnunez29
JNo323
JNo323
174
1,092
Middle, TN
Like @Hondasxs said, relocate the winch wire directly to the battery and not the isolator. This ensures it draws from the battery you want it to.
