P700 Homemade sound sytem
jcmason
jcmason
17
35
Minnesota
Ready Installed Dash Dash pod
Dash pod Installed Ready
alloutdoors
alloutdoors
1,022
2,184
US
  3. Do not currently own
Looks nice and weather proof?
Backwoods
Backwoods
37,750
376,076
Douglasville ga
How does it sound? I just went the easy route i bought a blue tooth i liked at best buy it sounds good as factory car stereo . And have spotify on my phone that way at least I like every song since I'm the one that picked them.
BBOOTH
20
wisconsin
I purchased the Noam Nutv 4 quad blue tooth kit for my 2018 700-4 deluxe and wondering what is the easiest way set it up for "key on" to power it up. Saw on the Honda powersports website an accessory sub harness part# 08Z01-HL3-600 or do you simply tie into your cig lighter? any suggestions are welcome.
Backwoods
Backwoods
37,750
376,076
Douglasville ga
I tied into my cigarette lighter no problems but if I would have thought ahead I would have got the harness. I just wanted to finish it then.
BBOOTH
20
wisconsin
sounds good... thank you... I am sure I will be posting more questions
jcmason
jcmason
17
35
Minnesota
Backwoods- sound is perfect- crystal clear , TONS of Bass, load as Hell!! goes up to 40 I think but cant sit in there past 25 HAHA..BOSS marine head unit is AM/FM , Bluetooth also -so I use Pandora or Spotify .I'm currently running Pioneer 760 WATT and thinking of adding another 760watt so I have to power only Subs- Some have asked if it weather proof.....only head unit. the roof system is not, but windshield and roof protect.
Reactions: Backwoods
jcmason
jcmason
17
35
Minnesota
Alloutdoors- no the roof system is not weather proof- but there is a roof over top ,windshield and back window to protect that as well. The head unit is weather proof- BOSS Marine MGR350 -crystal clear output
196,304
BBOOTH
20
wisconsin
so I ordered the sub harness above and went to install when I notice that the Warn winch that I had installed at time of purchase is already tapped into the accessory plug (cig lighter). Do I have to find a different power source for key on operation for my blue tooth kit or can I hook into the same accessory circuit along with my winch??
196,304
I'd hook up the harness and then wire your winch switch into that. Not much different than the way it is now but would be a cleaner way of doing it.
BBOOTH
20
wisconsin
you don't think that would be to much on that circuit with having the winch, Bluetooth system and cig lighter?? with a 15amp fuse.
196,304
I'm assuming it's just the winch switch that's hooked to that circuit? The harness plugs in and gives you 4 hots and 2 grounds on the P5, don't know if the P7 is the same?
BBOOTH
20
wisconsin
sounds good... thank you so much
BBOOTH
20
wisconsin
FINISHED!!! NOAM NUTV4 QUAD.... also routed a remote aux cord outlet in glove box... sounds awesome.
IMG 20190425 225800959 IMG 20190425 225814286 IMG 20190425 225827869 IMG 20190426 074009222 Screenshot 20190426 171106
