P500 HELP need MAP sensor wiring colors?
DSG2
DSG2
11
16
Sorry to bother everyone but I have a slight problem on my 2020 P500. I had a rat chew my MAP sensor wires. I ordered a new plug but I can’t tell what color order to require the plug. I would really appreciate it if someone would take a picture of the color order their MAP sensor is wired.Thanks in advance!!!
0A77017E FFEB 4289 9F8D C52573DF2DE3
  • Wow
68,132
More.
*Assuming the little tab aligns with the tab.
Can you confirm the one to the left is empty on your's?
1650155327315
Reactions: DSG2
68,132
Left to right. Latch topside.
*** Facing the connector looking at the pins **** (NOT the pin insert side.)
1, 2, 3, 4, 5
1 Empty
2 Brown with white stripe
3 Green with white stripe
4 Blue black stripe
5 Light green.
Reactions: DSG2
68,132
1, 2, 3, 4, 5
1 Empty
4 Blue black stripe
5 Light green.
Still would like to get a visual conformation.
Dave75
Dave75
123
500
Do not if it’s the same, but here is a P520.
This is the best photo I could take.
Used some Rodent Repellent after your story.
AC9D8BFB F675 4B3B B912 3B4711C02509 25729E40 9440 47AA AA53 6266B0D9E85A
68,132
Thanks a lot @Dave75
BUT....
That is the IACV. I needed it also. so appreciate it.
The map looks like it but is about twice the size. It is actually a 5 pin connector but will only have 4 wires.
It should be in the general same location on the side of the throttle body.
DSG2
DSG2
11
16
Man guys I really really appreciate your help. So, I’m thinking left to right looking latch up mouth up…light green, blue, green white, brown and blank
Dave75
Dave75
123
500
It’s hard to see in the photo, there does look like a blank plug for the 1st pin on the right side.
Please post photos of your work.
Hope you get it back on the trail soon.
