P1000 Heat ideas for Rear Passengers?
cboyda
Alberta, Canada
Woot, Wetaskiwin Search and Rescue has purchased a 1000-5p deluxe and adding enclosure/roof/heater, but the dealership is saying there is no way to heat the rear. Was really hoping to put the floor vents on their feet for the rear passengers. Any suggestions?
Just thinking of some way to extend our winter, night operations...
Ridinfool
Ridinfool
36,144
386,049
Western North Carolina
First off, welcome from the mountains of WNC
Second : We love pics, because with out them it never happened.
Third : There will be plenty of heat for the back passengers, unless your riding in subzero temps then maybe not, I would test it out first before adding something I may not need.
TxDoc
TxDoc
2,252
7,532
TEXAS 🇨🇱
photos.app.goo.gl
Welcome from Texas.
I don't know if this helps, or not.
For those who wanted heat, I had 12 volt electric blankets. They could wrap over their legs and sit on it and they could wrap around their shoulders and chest.
They got heat and kept the wind off. When we had the below zero temps for a couple of weeks, it was great
I don't know how cold your temps get and how well it may work.
But, good luck on your search.
Sent from my motorola edge plus 2023 using Tapatalk
Vikes79
Vikes79
SKOL!
11,955
115,182
South Dakota
  2. Talon X4 LV
As hot as the back seats get in normal conditions I’d say it’s going to be fine, provided you get the huge gaps under the rear doors sealed up, and the gaps at the top of the roof line.
toddvdh
toddvdh
1,119
7,407
Green Bay, WI
the back seat should be fine. It’s warmer than the front in mine.
I got creative with some pipe insulation and zip ties to close the gap at the bottom of the door. In the front I used some stick on gaskets.
Rayger143
Rayger143
3,298
28,771
Winfield, BC Canada
I wouldn’t be concerned if you are getting a full enclosure and a heater. Like @Vikes79 said seal off your gaps. Being part of SAR you probably are wearing good winter gear and in my opinion that’s how you stay warm.
Robobrainiac
Robobrainiac
2,687
9,317
I just remembered seeing this
Is there room for the rear passengers if you spun the heater 180 degrees for them to enjoy the mr heater benefits?
This might be helpful for you.
Reactions: Prntckt and TxDoc
DRZRon1
DRZRon1
1,415
4,352
I'm half tempted to strap one of my Honda eu2000i inverter gennie onto the back of my 700 and run space heaters...
Sent from my SM-S911U using Tapatalk
Smart man - or buy a used Jeep and outfit, cheaper, better and no sealing, stuffing, heating - lol….
Prntckt
Prntckt
1,105
7,712
Altoona, WI
Welcome to the forum from west central Wisconsin.
Warm clothing, sealing up gaps and a good heater like an Inferno are the best steps in my opinion
Reactions: TxDoc and Rayger143
Bighat
Bighat
909
3,866
Gallipolis Ohio
I've thought about installing heated seats in mine in the front. I don't have a 5 so this my not work for the rears. Dorman 628-040 Dorman Seat Heater Kits | Summit Racing
toddvdh
toddvdh
1,119
7,407
Green Bay, WI
I forgot about that on mine. I have 4” thick heated seat cushions for the rear. That definitely helps. The rear seats are too low, even for 6’ adults.
And they work good in a tree stand, fishing boat or Packer game also. :p
They are similar to this although mine were from wal mart.
IMG 0157
Robobrainiac
Robobrainiac
2,687
9,317
That is a cool concept to have them permanently mounted.
I used an automotive "cover" that I enjoyed alot. The electric heater I tried did not work well. It was only enough to warm your hands over it when needed.
Post #93
Reactions: toddvdh and TxDoc
StewB
StewB
766
3,548
I bought two Mossy Oak - Wally World 3" electric hunting cushions like these. They fit perfect, make the rear seats better year round, and you can rig them to use vehicle power instead of battery (mine use standard USB power). When out in the cold, we throw an old sleeping bag across our laps and it works.
I also have a heated vest. If you haven't tried one, you should. It's magic.
Reactions: toddvdh
bumperm
bumperm
1,921
6,820
Gardnerville, NV
Look up car seat heater kit. I installed a kit and improved lumbar support in my Honda S2000 (didn't come with that feature and it sure is nice). Look up car seat heater (and also add the work "kit" to see options for adding just the heater elements to existing seats).
Haven't done this on a SXS, but it's done all the time on small aircraft. Install a metal shroud around the engine header pipes. The shroud should have a gap of a few inches and not be near or touching pipes. Then use flexible ducts to take heated air to the foot well area in front of seats. The duct should end with an adjustable & closing louver to regulate heat. To force air through the system, on aircaft it's ram air from front engine cooling inlets. That might be doable in this app, but probably easier to use a bilge fan that many of us are using to keep the under-seat area cooler in the summer.
JMynes
JMynes
553
3,267
Augusta, Maine
I have one of those. It actually gets too hot for comfort sitting in the deer blind.
