Has anyone ever trailered a Pioneer on a military 3/4 ton trailer, either a M116A2 or a M101A2??
106,161
I was wondering if anybody has ever tried this before. Back in the day I used to have a couple of these trailers and I still do have a pintle hitch that swivels that attaches to the back of my truck that I pulled off of a M1009 CUCV Blazer. It spins 360* I had it mounted onto a raised extended hitch for towing tall military trailers. I’m kind of curious how this would look and function. I’d be towing it behind my f350.
The M116a2 was designed to haul generators
The M101A2 was designed to haul cargo and it has folding/dumping bed which was made so more could be hauled together on a train car. I want to say they’re rated for 1500 lbs and are towed by a fixed lunette ring.
EC6A3B28 0782 498D A7D3 894693BAAF6D
E45331A7 F1B1 46AD AA17 02C7D2335F0E
0635CBD2 8383 4123 A90E 9C3DD201FCFD
8997205A A44B 4B9A 8D5F 4A51084B25C6
6DA92496 D608 4079 8337 1D8BE0D5B5A4
8743B109 7DF8 453E A3B0 8D6046FCB36F
5,715
26,175
With the camper rig you're looking at, you'll need a place to carry fuel, that Military trailer is just big enough for the P1K. And the P1K is about 1700 lbs, already 200 over the trailer's 3/4 ton rating. I carry 47 gallons of fuel (~300 lbs), three 20 lb. propane bottles (~100 lbs), a 7 gallon water jug (~56 lbs) and a highlift jack, nearly 2400 lbs. including the 1900 lb. outfitted Talon.
106,161
Gonna add an under the bed 65 gallon tank for a total of 100 gallons. I think my truck has a 36 gal tank already. I’ll need extra fuel for the 1000 though. Maybe carry 4 speed bottles of gas. For long howdy treks and desert wanderings
106,161
I am considering an aluminum trailer too. I just want to keep it under 16’
5,715
26,175
I'm completely happy with my 14'er, Talons and P1Ks are close to the same length.
Under the bed of what, trailer? 100 gallons is ~400 lbs. I camp in one deserted spot and stay there until I've ridden everything in the area, it's not unusual to run out of trailer fuel before the area is done (47 gallons), so 4 speed bottles (5 gal. race jugs?) is only 20 gallons.
3500 lb. single axle maxxed out but I buy gas as close to camp as possible -
I f8vLC67 X2
5,715
26,175
I made a trailer box to increase my storage space when traveling -
Reactions: 100Acre
106,161
The extra 65 gallon tank is gonna go under the truck
Reactions: Farmer and CID
