P500 Hammerlock coupling links
waynester
waynester
254
1,250
Ga, USA
Would these be safe using correct or close fitting linchpin / receiver hitch pin or even high grade bolt/ wing nut? I'd rather skip the hammering.
Hammerlock coupling link Google Search
Reactions: crewcabrob
116,574
Several sizes available, also for linking chains. Apparently useful to Ford trk owners with oval safety chain slots
Hell yeah! I usually use a D ring on my SD hitch. might get me some of those instead. Kinda thought they might be for something like that.
thanks for posting.
they might be handy on a sxs as well
21,764
93,366
What are you trying to accomplish?
These are commonly used on Ford trucks as stated above. The hitches suck for using trailer chains.
waynester
waynester
254
1,250
Ga, USA
? Commonly used, but they suck? I don't understand.:confused: If they suck why commonly used? NO Bashing , just curious
21,764
93,366
The ford truck hitches suck for attaching safety chains.
Guys attach the hammer locks to make hooking up easier. Install once and forget about them .
Backwoods
Backwoods
37,783
376,280
Douglasville ga
Have you found them to be of use in wheeling? A quick connect would be useful, but not so a semi permanent hammering connect
No I personally don't see a use for riding but they are very good for their intended purpose.
waynester
waynester
254
1,250
Ga, USA
Mostly learning and exploring items I might facepalm myself for not having , after the fact . I learn more by picking you members experienced brains then picking any part of myself.
196,740
Chevy's have the same problem. 2 1/2" receiver but chain loops that can't be used as is. Went through several shackles to eventually find the right size. Not that I ever will but they can be easily removed.
Reactions: Remington
