Probably still be stuck in the gravel if I had those frontline ACP’s
JATLol @Bcavin351 upgrades….
Was a good day, didn’t need a cutoff wheel or a welder. Passenger knuckle was trash, balljoint just flops around and the bearings were obliterated. Threads on the ball joints were toast too
View attachment 400893View attachment 400894View attachment 400895View attachment 400896
I noticed the G/Products lwr bushings have a smaller OD sleeve which leaves more wall thickness for the bushing material. I just replaced the RB3’s …..we’ll see how long these last.I don't know bout the others but RB3 bushings are groved inside so grease can reach the sleeves. I've had no problem with them other then my right front upper but that was caused by the bolt phucking up the hole in the frame tab so it started to create a little bit of play........stupid rough TN trails!!!![]()
Im missin a fire. Fire ban since June here
I was disappointed myself..... where's the tires?
