P500 Good wheel/tire set up for snow and some sand???
Dschaffer
32
81
Yes, 28s would have fit.
Yeah. I’m starting to see that plenty of folks have success with 28’s. I wonder why there are also lots of folks that say they won’t work? It makes the whole tire/wheel purchasing experience much more difficult than it likely needs to be. Different brand tires having different actual measurements doesn’t help much either. I’ll know once I get them mounted, but I’m 99% sure that with the wheels and tires I purchased, 28’s would fit with zero issue.
192,821
You're in a 500 thread and no they wouldn't, unless you're okay with the rubbing.
Some guys are alright with it but it's kind of a fail IMO.
Very true to size. The 28x10 Megabite tires measure right at 28 inches tall when inflated to 15psi and under weight....
sure you could stuff it in there but without further modifications they will rub.
Reactions: Scoop and futzin
Dschaffer
32
81
Good to hear its the right choice! I didn’t realize I was in the 500 thread. I guess I also didn’t realize there would be a differance. I’ve been reading that I’ll want to keep the tires around 4-6psi for a better ride. I’ll mess around with it and share what I learn.
192,821
You're in the right thread, the 500 and 520 are essentially the same machine. By getting 12" wheels you've helped the rough ride some already as you'll have more sidewall than a 14". Running lower tire pressure helps as well, I'd start out about 9 or 10psi personally and see how it rides. Too low of pressure causes pinch flats and possibly a bead leak.
You got the right size and like Futz said, we won't BS you. 👍
futzin
futzin
4,708
34,523
Kentucky
20231002 143814
20230902 160700
27x9x12 front
27x11x12 rear
4+3 offset
The fronts rub frequently. Not as much on my 500.
Thought you had a 500, I missed that part.
Dschaffer
32
81
I decided to put the tires/wheel on today without the rear 1” rear spacers. I’m not sure what’s up with RB3, but I ordered the spacers last week on Monday and still have yet to recieve a shipping confirmation. I sent them an email yesterday, so hopefully I’ll hear back soon that they are on the way. As you can see from the picture with the wheel turned, 28”s would definitely rub. The 27”s should be good unless tight cornering over rough terrain. A quick tape measure shows around 53”s wide with this set up. It definitely brings some character to the machine. I’m sure the tires will perform much better than stock. Thanks again for all the help.
IMG 1696
IMG 1697
IMG 1698
IMG 1700
IMG 1702
IMG 1703
IMG 1704
futzin
futzin
4,708
34,523
Kentucky
Looks great. What height do they measure, if you dont mind?
Mudwisel
Mudwisel
10,077
83,416
Tampa Bay Florida
I dont have a 500 but I have been running megabites for about a year. My observations are they work about the same as bighorns in sand. So maybe that would cross over to snow also. I like the megabites everywhere else including mud. The megabites are a stiffer tire so I run less air. I am at 8psi in front and 10psi in back. Just personal preference. IMO they look good on your ride
