P700 Full size battery
BrentW
26
14
Arkansas
Can a 2016 700-2 be run off a full size car battery? Would the charging system be sufficient? Seems to be plenty of room under the drivers seat to mod a mount. Anybody running this type of a set up with just a single auto size battery?
swsebek
swsebek
2,854
5,835
pa
Yes a lot of us do it.I have a car battery and the stock battery with Isolator.My headlights and starter run off stock and all my accessories run off car battery.
IMG 4844 IMG 4740 IMG 4742
BrentW
26
14
Arkansas
I have just had bad luck with small batteries in the past. I would like a battery to last more than 3 years. I run a light bar and at some point may have to use my KFI 4500# winch. My machine is ridden several times a week so it isn't just setting up.
hydrantman
I have been running a Yellow Top Battery in my 2014 for almost 4 years now, no problems.
allgm1
allgm1
1,049
1,485
New Hampshire
I've been running a full size battery for the last 2.5 years, I need it with the plow, heater, and tune all working at the same time, small battery's can't keep up. Definately well worth the effort in my eyes.
Martinezpj90
Alaska
So I am a novice and just purchased my first 2015 pioneer 700-4 coming off the Polaris wagon. The pioneer has a full soft cab plus a heater. As I am located in Alaska and winter brings a large amount of dark time, I would like to put some led lights on it and have been reading up about pros and cons of two same size batteries or just running a full size one. For running a single full size battery, Is it as simple as running a longer ground and power cable to a new location and calling it day or is it more involved?
thanks
Patrick
Reactions: 70Bones and Mudwing
Mudwing
Mudwing
36,959
306,672
The Mud holes
thanks
Patrick
Yes, it’s that simple. Just extend the wires. I don’t think you need to upsize.
Reloder28
Deer Park, Tx
So, if I read this right, you can install a larger battery of your choosing & the stock charging system will keep it up just fine? And this will relieve the need of two batteries, isolators & all the hoopla?
70Bones
70Bones
888
3,779
New Brunswick Canada
One of the reasons people use 2 batteries and an isolator, is so they can run the extra battery dead and the engine will still start off the original battery. However, if you put 1 large battery in it, and carry one of those cigarette pack sized car boosters for emergency starts, you're golden! I always have one of those pocket boosters, they work great!
1588554749683
L
lowrider
1,741
3,688
Idaho Panhandle
I have run two batteries in my boats for at least since there was electricity using an A/B 12 v switch...A is start (radio and stuff) and B is trolling motor. I was planning to do that at some point in the 700...other than having to make a decision on which to use it's very simple. I do trickle charge at home but I can charge off my truck battery if needed. The big marine battery just never seems to run out of juice.
My concern with the 700 is will the charging system keep up with demand especially with winch use, blower motors on the heater and so on?
I have one of those handy little starter things in my truck...never needed it so far.
