Gator
The Most Unknown Member
I have run 1inch aluminum spacers for 1 year...At first I did front and back,Shortly after I removed the rears because 1inch was too much.The spacers gave me room to run my 28s,but the ride is no better......I will be getting fox shocks for the ride and the ground clearence
what is that? U install them then u can adjust the tension on the spring? so it makes the shocks adjustable? If so has anyone tried them yet on the 1000'sthese will fit the stock front shocks according to the measurements. I just took mine apart again to check.
http://www.speedwaymotors.com/Bilstein- ... ,6871.html
Iv got 2 1/4 inch spacers on front with super ATVs lower arched a arm and I run 30s just fine they will hit every now and then in big rutsWhat size tire can you run after a spacer lift? Is it possible to clear 30s?
