P700 Front end problem
cjm
6
I have a 15 700. Recently the front end has a knock to it when I turn or put it in 4wd. Anyone have an idea what maybe causing this ? Thanks
Reactions: Lady01
116,574
Yea similar when it’s in 4wd it’s a constant knocking. How would I know which axle is gone bad ? Thanks
You need someone outside close to the front rig as you turn and roll in order to pin point witch one it is. How many miles on the rig?
imo if its like you say, a 15’ #POIDH, and its the original axels, Id just upgrade and replace both and keep the other good one for a spare.
cjm
6
Ok I’ll give that a try. It’s a 15 model. I bought it brand new. Never had any trouble except for the seats coming apart. Other than that it’s been great till now.
swsebek
swsebek
2,854
5,835
pa
A lot of times you can get the unit on a steep incline and shut engine off and coast forward or backward turning it left to right. Having someone else will help too. I totally agree with Remington. Replace both axles together as a set.
