Alaska350 Well-Known Member Feb 17, 2021 113 257 63 Anchorage, AK Ownership Do not currently own Jul 24, 2022 #61 joeymt33 said: You may have to remove both tie rods and turn the rack so it sticks out the driver side. This will give more access on the passenger side. I don’t think there is a bushing in the driver side. Click to expand... Is it do-able without removing both sides?
Admin HondaSxS.com Advertisment Remington POIDH Enforcement Officer Lifetime Member Supporting Member Jul 24, 2016 20,353 116,521 113 Michigan Ownership 1000-5Talon X Jul 24, 2022 #62 Alaska350 said: Is it do-able without removing both sides? Click to expand... Joey hasnt posted on this thread in a long time. Your best to send him a PM and he may get an email to answer you directly. Reactions: CID P1K5Dave Well-Known Member Lifetime Member Club Contributor Jul 11, 2020 2,318 8,634 113 Petoskey, MI Ownership 1000-5 Jul 24, 2022 #63 I don't believe I had to remove both sides. You will want to check your left inner end while your in there though. Alaska350 Well-Known Member Feb 17, 2021 113 257 63 Anchorage, AK Ownership Do not currently own Jul 24, 2022 #64 P1K5Dave said: I don't believe I had to remove both sides. You will want to check your left inner end while your in there though. Click to expand... Left inner? P1K5Dave Well-Known Member Lifetime Member Club Contributor Jul 11, 2020 2,318 8,634 113 Petoskey, MI Ownership 1000-5 Jul 24, 2022 #65 Driver side inner tie rod end joint. Just check to see if it's solid while you're at it. Reactions: Alaska350
