P1000 First service
koma
koma
147
736
East Central Illinois
I just completed my first service and was wondering why my OEM filter came with two different size o-rings.
Did I miss something or was it a mistake from the factory or same filter for a different model?
Reactions: Remington
The filters shouldn't have come with any o-rings.
Did you change both Engine and DCT filters?
The o-rings provided were probably for the filter covers. But if you got OEM filters they aren't provided with the filter, its a separate part number.
Scoop
Scoop
5,440
21,394
  3. Talon R LV
Maybe he just meant there were O-rings included in his order, not literally in the box with the filters.
1683817880848
koma
koma
147
736
Sorry, The air element came with two o-rings.
one that fit and the other was oversized by at
least six inches.
Yes I already flipped the oil, oil filters and o-rings for them.
Also flipped the sub tranny.
least six inches.
The air filter o-rings fit as long as you don't stretch them. They need to be laid in the groove and not stretched or they will end up being too long.
Reactions: CID
tjoreo
tjoreo
1,032
1,992
Southern Idaho
According to the parts diagram. 1 is for the case seal and 1 is the lid seal. Parts #4 and #8 in the diagram. This is a 2021 model.
Medium
Reactions: Scoop and Smitty335
212,771
When I removed the lid, there was no gasket but there was one under the filter.
Well, that explains it.
Thanks
That's what I thought first air filter service, the air box gasket was really compressed and I didn't see it. Don't see as well as I used to.
TripleB
TripleB
21,080
183,371
Caryville, Tennessee
I changed mine for the third time today. This one has 5000 miles on it. I changes the other 2 at 4000 miles each and they looked about the same. I stil haven't replaced the gasket. I did finally strip one of the bolts out today. Added a about an hour to the job.
5,758
26,443
Thanks
If you poke in the groove with something pointy, you'll find it's squishy, not hard like the plastic. The gasket is the same color as the plastic and hard to see that it's actually a gasket. You won't be the first to be fooled.
