Mopower58
Unburdened by what has been!
BH 2.0's are lighter than the originO
Thanks Trig,
is that width estimate accurate?
Husker!, ... thanks for the shoutout. So you run 26X9 on all four corners? Did you consider a wider back set? Why did you choose the BH's? What are you at width wise front and back?Lil red somewhere there is a difference in weight that I made between stock and bh2.0 s on stock wheels. I also run 26x9 on stock wheels with 1 1/2” spacers and have outside dimensions.
I stayed with the stock steel wheels just thought a little wider couldn’t hurt so I added the spacers. Love tires they hold great and ride better. They will work good in Colorado. I’m going to try and make the Colorado ride this summer. I would like to use 50” trails but don’t know how tight the trails gates are.Thanks Husker, weight and width-add is obviously the concern and so I assume with the lighter profile of 2.0's you managed that nicely. 52.5" would seem very manageable for the trails I see and ride. I don't understand the difference between the effect of spacers and wheel offsets but assume you didn't change offset when adding the spacers. It is just very clear (although the stocks survived the trials), something with a more agressive and tougher construction/tread on a slightly wider base plus additional travel without adding much weight would be very helpful in Colorado.
Appreciate the specification detail ... you obviously like your setup, yes? Do you know why others choose/prefer wider back tires?
As for our team(s) ... the ice age will end, just hope its soon.
GBR
Lil Red
I would like that.Husker,
I'll keep the stocks as well. Let me know if you come out ... maybe we could tandem-up.
Red
