P500 Fault code 112-8?
O
Ollie3151
40
Australia
Hi, My 500 (2015), is showing is flashing up this fault code 112-8
The 500 starts, runs for about 5 mins and then the gear display goes blank followed by the engine light coming on and the 500 shutting down.
Any ideas what I should be looking for.
cheers
ollie
cheers
ollie
There isn't any code with that large a number, nor is there any code with a -8, it would be -1 or -2 but the P500 display doesn't indicate the secondary number anyway.
Is the CEL or gear position flashing?
The unit will flash multiple codes, 1 after the other and then reset with a long blink.
116,566
cheers
ollie
Welcome Ollie, from the USofA
When u get a sec, post up some pics of your ride as well. Kind of a u written requirement here Just to make sure your for real or these guys get mad ;)
POIDH
O
Ollie3151
40
Australia
Really good points. I will try a get a video tomorrow.
But, in The interm, i turn on the key, the gear display (on the dash) flashes once then there is a pause, flash’s again then another short pause, there it flash‘s Twice in quick succesion, then a pause then it flashes eight times quickly. This continues to repeat.
Fatsquatch
Fatsquatch
Approved Member
120,949
1,009,007
Hidden
Dont need a video, just a picture of the rig
Video of the code flash sequence could help figure out for certain what the code is though
@Ollie3151
And a lot of people ask when they try uploading their first video so the Protip is to upload it to YouTube or similar first and then just post the link to the video here.
O
Ollie3151
40
Australia
Here is a couple of pictures of the ATV. It’s 500 purchased about 2015-16.
The photos where taken in East Gippsland about 30 km (20 miles) north of Bairnsdale, Victoria Australia.
I will take some more photos of the bush land around the area once I get it running reliably.
IMG 3571
IMG 3568
IMG 3570
IMG 3563
O
Ollie3151
40
Australia
When I started the ATV today, there was no flashing of any codes. About 5 mins after driving around, It shut down again. I did capture a short video, but not sure how to upload it. Attached is a photo of the display.
IMG 3072
500oneer
500oneer
15,000 mile club
428
1,083
Central PA
When I started the ATV today, there was no flashing of any codes. About 5 mins after driving around, It shut down again. I did capture a short video, but not sure how to upload it. Attached is a photo of the display. View attachment 408826
My 500 was shutting down after 5 minutes and throwing codes. I replaced the battery and spark plug. That did nothing. Turns out it was the stator. You have to take the engine out to fix that.
