P500 EPI cutch springs for 28’s
281,105
Anything over 27" I believe you have to trim the front frame to avoid tire contact. That said, engine hp is low enough the clutch will likely be fine without aftermarket springs.
Splorin
320
904
Maine
jak did an install. Bit of a project. Mine are on a shelf. Have 'em on my Big Bear. You can get by without but when you have 'em, they're great. The older P-5s are geared lower which helps but even my 15 with 28s can use the 'jump' they provide with second gear launches.....
Kkettlebell
Kkettlebell
114
475
Nova Scotia
Let me know how you like them when you get them installed
