P700 Engine Heat
G
gawnfishin
11
Just picked up my 700-2 deluxe last Saturday and having a blast. I must say though, you would think that after seeing years of complaints about exhaust and engine heat under the seat, Honda would have corrected this. I am in south Louisiana and it's hot. While in the winter I will appreciate it, I am not enjoying the butt griddle right now.
As for exhaust tape, has anyone wrapped over the heat shield? Begrudgingly, I am also going to insulate the engine compartment as well. For $17000 you would think that there would be no engineering modifications to do.
Reactions: Lady01 and Kinlaw
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
That's just the beginning
43,569
The emissions regs are causing them to run much hotter than the original 2014. Didn't see too many complaints about those.
Honestly, one of the best things you could probably do is maybe a Power vision to fatten it up a bit.
I did heat shielding. I'm scared to wrap the exhaust directly, as some claim it makes them eventually crack. Don't know about doing it over the shields...
FlipKing
FlipKing
139
298
Insulating under the seat caused issues for me, so be careful with that. I also upgraded skid plates though.
Reactions: Remington
Dockman
Dockman
168
344
I put heat shielding under my seat. I also sealed gaps around gas and brak e peddle. Major improvements!
Heat around pedals
P700m2 - Heat around pedals
mygreenbronco
mygreenbronco
25
68
Centralia, WA
I put on an after market exhaust and removed the cat (thats its job to get really hot and burn excess fuel) It dropped the temp in the up pipe also.
