P500 Dust Coming Through
Shadesmn
Shadesmn
505
959
Ramsey, MN
My we see a pic of it?? Please
If i put my arm by it when looking back to back up she starts flapping my sleeve if its close:)
20170326 113949
Shadesmn
Shadesmn
505
959
Ramsey, MN
And pre snorkel..also about 200 miles or so here.
20161221 182344
Reactions: idcwby
196,389
does it really help cut down the dust? My concern is do you lose any power with air having to be drawn that extra distance. If you put an elbow at the top and face it forward then its going to suck more dust and if you face the elbows facing back then it seems it would be difficut to draw air. What are everyones thoughs on this?
That was a concern I had when doing mine. That's why I went with double 1 1/2" stacks, actually gave it more air. I swear it's hitting the limiter quicker than it used to.
Reactions: rocmar
906UP
906UP
15,057
143,114
da Yoop
No worries about air flow with a snorkel, a 475cc engine running at 6000rpm needs approx 100cfm of air. A 2" sch40 pipe(ID of 1.8") at sea level(0 psi) can flow 840cfm @ 3' long, 595cfm @ 6' long. Other variables such shape, elbow would affect this as well but still well within the needs of the engine.
rocmar
rocmar
4,741
5,778
4 CORNERS
I understand taking the windshield off, but as we go towards fall I was really looking forward to keeping those fridged morning rides a little warmer.
As I've been looking at the front it looks like the major holes are where the pedals and 2wd/4wd selector is. I think figuring out a way to seal those and it may cut out the dust.
idcwby
Those holes ..letting in dust..
also let's in warmth...in the winter
just sayin
Shadesmn
Shadesmn
505
959
Ramsey, MN
Its a screen/drain cap piece. I believe it fits the id of the pipe so i had to cut a piece of pipe the length of the collar on the 90 and then glue it inside the pipe and then inside the 90. I dont recall for sure but i think that was how it was.
20170726 224737
Reactions: rocmar and idcwby
rocmar
rocmar
4,741
5,778
4 CORNERS
Keep in mind when you exericence all that dust in the cab gets into everything. By this I mean if you are riding in a lot of dusty areas check your air filter OFTEN. I have to clean mine every couple of rides and you would not believe the amount of dirt that gets sucked into the air filter.
Correct...
I do mine...at least once a week
this place is...Dust City,USA
906UP
906UP
15,057
143,114
da Yoop
How do they let heat in? What's putting out heat in the front?
idcwby
The radiator/fan but IMO it's negligible at best, given the amount of open area under the hood it's not a reliable source of heat. In the Northern climates, especially in winter the fan rarely turns on regardless of the vehicle.....quad, car, truck etc.
Reactions: idcwby
196,389
Just an idea, cut a small piece of pipe at an angle to fit in the last 90. Gives it a hood so water won't just roll in. Used drain covers for mine too, fit in the 90 so small pipe piece holds them in. Opened them up a little in the centers with bigger holes.
Snorkel tip Snorkel tip 1
rocmar
rocmar
4,741
5,778
4 CORNERS
Between that heat & seat belt heat...
Plenty toasty...in this neck of the...
woods....mean desert
Reactions: Mudder
sgerksinwi
sgerksinwi
203
264
WISCONSIN
View attachment 50251 View attachment 50252
Do you use any type of filter at the opening??(pre filter or just the one in the box)?
rocmar
rocmar
4,741
5,778
4 CORNERS
Just the one in the box. We have a lot of water and humidity here, have only been on one REALLY dusty ride.
Dude should of said..
you were DUST....DEPRIVED
...I WOULD OF MAILED YOU
...A whole frickin...box worth
haha
Reactions: idcwby
rocmar
rocmar
4,741
5,778
4 CORNERS
NOOOOOOOOOOO!
I've done it. The dust sticks to the rain-X. It's worse.
Yep..
anything with oil or..
wax base..just makes it stick more
idcwby
idcwby
106
201
Would Spray Foam fill those holes and not cause issues?
idcwby
