Razorback
Drowned out yesterday. Think I only got water in the fuel tank. I have the intake snorkeled. But that is all. Is there away to drain the fuel tank or does it have to be removed?
I would remove it. It's easy.Drowned out yesterday. Think I only got water in the fuel tank. I have the intake snorkeled. But that is all. Is there away to drain the fuel tank or does it have to be removed?
Yes you can sifen it and check your oil too.Drowned out yesterday. Think I only got water in the fuel tank. I have the intake snorkeled. But that is all. Is there away to drain the fuel tank or does it have to be removed?
Vent line. Never got around to extending it when I snorkeled the air intake. Everything will be before it goes out again. Changing oil, diff oil, taking fuel tank out, get fuel pump assembly out of tank, take it apart to get to the fuel filter. Now have to wait till Tuesday for the dealership to be open to get a new filter. Then put it all back together. Advice... VENT EVERYTHING!!!How did you get water in the fuel tank /.? Gas cap off ?
Advice , get a boat .![]()
Found out after I got pulled out a truck with 44's had to be winch out of that mudhole. And I made it further than he did. Made me feel a little better.A boat big enough for the p500 won't make it down the river.
