P700 Door Rattle Cheap Fix
lgl5433211
lgl5433211
5
Houston, TX
Howdy! Just got a new Pioneer700 -4 non Deluxe and noticed lots of rattling on my test drive. Dealer said this was normal on Hondas. Tried to adjust rubber bumper but not much luck. I wrapped the the Metal door latch in 3M Scotch 130C Linerless Rubber Splicing Tape and seemed to fix the issues so far. Added some grease just in case as well. Thought I would share.
IMG 4285
Russ989
Russ989
22,645
147,291
Yeah that adjuster is always a 1/4-1/2” short.
Backwoods
Backwoods
37,750
376,083
Douglasville ga
What do you slide that over the stock adjuster?
Yes adjust it out some test it till its good then put a couple rounds of black tape that you will never see . Mine has been going.strong.for 21/2 years.
Dockman
Dockman
168
344
Yes adjust it out some test it till its good then put a couple rounds of black that you will never see . Mine has been going.strong.for 21/2 years.
Good tip thanks
Reactions: Backwoods
43,588
You'll be doing this to the bed latches soon...
Reactions: livefromthetree
